POV-Ray : Newsgroups : povray.advanced-users : Heightfield problem Server Time
16 Dec 2025 20:10:17 EST (-0500)
  Heightfield problem (Message 15 to 24 of 24)
Subject: Re: Heightfield problem
Date: 19 Feb 2002 15:55:25
Message: <3c72bbbd@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> Or just use one of the height field macros from shapes.inc. ;-)
I think he's trying make a HF out of a satelite picture, so I'm not sure
those macros would help. Still, should be easy to write a similar macro that
uses as image.
 -Shay
Date: 19 Feb 2002 16:15:53
Message: <chrishuff-F9CFE9.16153919022002@netplex.aussie.org>
In article <3c72bbbd@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> uses as image.
The macros take functions as input, so there is no problem with using an
image.
Date: 19 Feb 2002 16:24:05
Message: <3c72c275$1@news.povray.org>
> image.
That's right. Wasn't thinking straight.
 -Shay
Date: 19 Feb 2002 16:37:51
Message: <MPG.16dc658922b4245d989686@news.povray.org>
> > uses as image.
originally, it's DEM->TGA->edited image.  So yes, USGS data initially,
then edit it, then make a very high res terrain from that.
> image.
I'll look into that.  I tried a mesh earlier, using Wilbur as a TGA->
Mesh converter, but it's normal calculations were broken, so it looked
quite faceted.   Even with the broken normals issue aside, I wasn't able
to get that many points into the surface before running out of memory /
hitting internal POV limits (I've got 1.5GB RAM--maxxed for this
machine) I think POV maxxed out parsing a 500x500 point mesh inc file.
But by using a macro, I might get farther without having to have a
several GB .inc file to parse.
It was also much much slower, parsing such a huge .inc file, but I can
live with that if it ends up working.
Date: 19 Feb 2002 17:48:24
Message: <chrishuff-E0835F.17481019022002@netplex.aussie.org>
In article <MPG.16dc658922b4245d989686@news.povray.org>,
I don't think POV should be that limited, it might be some other
problem...but you might get around it by using several meshes. And with
the macros, you don't have to have the mesh resolution the same as the
image...because it uses a function, you could just use a lower
resolution for the macro and let the image_map interpolation take care
of things. If you need a higher resolution for a specific area, you
could generate a smaller, higher resolution height field for that area.
The macros won't help the speed, though they have the advantage I
mentioned of allowing you to pick your mesh resolution. The macros parse
slower than a mesh include file, which is why I added the option to
output to a mesh file.
Date: 19 Feb 2002 18:26:09
Message: <MPG.16dc7eed92fb5086989687@news.povray.org>
A 300x300 point mesh worked, but looked pretty rough--not enough points
(I'm rendering a 20K x 10K pixel image, so it's very very high res and I
need a lot of detail in the terrain map)
I just tried a 1000 x 1000 point mesh, which I think might be enough
points, but POV choked.  (internal error)  An 800x800 mesh also choked.
It claimed to generate an error log, but I couldn't find it.
Multiple meshes might be a workaround, but I would be concerned about
getting them to line up without gaps.
> of things.
sure.  My  image map is 5K x 5K pixels (actually, I've got versions from
500x500 to 10K x 10K).  I'm not trying to make THAT many mesh points--
that would kill anything  :)   I guess that's one of the advantages of a
height field--high res...if it's smoothing would work at that zoom
level.
But even a 1000 x 1000 point mesh would probably be good enough.  But
that seems to kill POV--I don't think it's memory--the task manager
reports plenty still free and usage still under 300MB.  But something
inside POV dies.
no, I pretty much need that much detail across the whole thing,
unfortunately.  I'm pushing things to the breaking point, it seems.
Subject: Re: heightfields
Date: 19 Feb 2002 18:39:41
Message: <3c72e23d$1@news.povray.org>
<snip>
    I think I see the problem, did you use more colors in the heightfield,
or did you just save as a higher resolution, then it wouldn't smooth and
would look like your picture does when two when the color changes more than
one shade.  Try lowering the number of colors in the picture you make the
heightfield from.  That seems to be your problem, although i'm not sure.
Try lowering the depth to the original.
<snip>
Date: 19 Feb 2002 19:21:51
Message: <chrishuff-1DAD04.19213819022002@netplex.aussie.org>
In article <MPG.16dc7eed92fb5086989687@news.povray.org>,
Well...how about an isosurface? No more worrying about triangles at all.
Date: 20 Feb 2002 12:37:49
Message: <3c73deed@news.povray.org>
In article <MPG.16dc7eed92fb5086989687@news.povray.org> , Lars
???  POV-Ray does not generate error logs.  Are you sure you got thjis message
from POV-Ray?
What specific error does the message window / console output of POV-Ray show?
    Thorsten
Date: 20 Feb 2002 13:40:09
Message: <MPG.16dd8d67fb130dc3989688@news.povray.org>
> from POV-Ray?
I ran it again.  I think it's a windows message, meaning it's log will
be useless.  "pvengine has generated errors and a log will be created"
or something.  It didn't look the the usual windows crash dialog(s), so
I didn't recognize it.
