POV-Ray : Newsgroups : povray.advanced-users : Announce: SkyPOV 0.1 Server Time
27 May 2026 16:32:15 EDT (-0400)
  Announce: SkyPOV 0.1 (Message 1 to 1 of 1)
Subject: Announce: SkyPOV 0.1
Date: 2 Nov 2000 01:45:23
Message: <8FE01D1B3markwagner17gtenet@204.213.191.228>
Announcing.....SkyPOV 0.1!
SkyPOV is an unofficial version of POV-Ray designed to do atmospheric
effects.  It is based on MegaPOV 0.6a.  Due to computer problems beyond my
control, it is currently available only as source code.  If I can find
time, I will upload a Windows binary tomorrow.  If I can't, it will be
available next Tuesday.
To compile, download the SkyPOV and MegaPOV 0.6a source code, copy the
SkyPOV source over the MegaPOV source, and compile.
Source is available at
http://www.geocities.com/rengaw03/download/wskypovs.zip
Features:
 * Wavelength-dependant Rayleigh scattering
 * Infinite-light hack -- needed to make wavelength-dependant scattering
   look good
 * A few notes on how to use the program.
 * Two or three demo scenes
Features that might make a future version:
 * Colour curve post-processing to replace the infinite-light hack
 * Random rendering order
 * A polynomial parser to allow polys to be written as "3x^5+2xy+z-1" etc.
 * Assorted minor optimizations
 * Improved "quality" command-line options
 * Improved splines
 * Render time prediction
 * Fixed memory leaks
Might make it into version 99999
 * Variable IOR
 * Non-linear transforms
 * Spectral ray-tracing
Mark Wagner
Subject: Re: Announce: SkyPOV 0.1
Date: 2 Nov 2000 03:46:54
Message: <3A0129E2.7E9B9FCE@alpharay.de>
> Features:
>    look good
>  * Improved splines
>  * Variable IOR
> Mark Wagner
Sounds good!
Go hell, TerraGen  ;-)
Can someone upload a compiled version? (maybe on your homepage, Nathan?)
Paul
Date: 2 Nov 2000 08:02:58
Message: <chrishuff-32B9DD.08060502112000@news.povray.org>
In article <8FE01D1B3markwagner17gtenet@204.213.191.228>,
I am going to make a post_process filter which uses a spline to adjust
color values...is this what you are talking about?
You mean it picks a random pixel each time? Another thing that might be
nice: some kind of "progressive" antialiasing, that renders the image
without antialiasing and then makes several "refinement" passes.
>  etc.
Couldn't you use isosurface functions? I haven't had a look at your
patch yet, so I don't really know what this is for...
I hope command line options aren't necessary for this...you should be
able to specify all options in the scene file. Or are you talking about
changing the "Render Quality" option syntax?
>  * Improved splines
I would suggest using one of the spline patches...less duplicate code,
more standardized, etc...
Christopher James Huff
Date: 2 Nov 2000 11:13:29
Message: <3a0192a8@news.povray.org>
In povray.general Mark Wagner <mar### [at] gtenet> wrote:
:  * A polynomial parser to allow polys to be written as "3x^5+2xy+z-1" etc.
  Why, when we have isosurface functions already?
  Isosurfaces even render faster than polys (I had a hard time admitting this
at the beginning, but currently I'm quite happy about this).
Date: 2 Nov 2000 15:47:16
Message: <3A01D3E8.8C98EF92@unforgettable.com>
OH YEAH, BABY!! XD
So to those of you out there concerned with such things.. how long until
someone churns out a Mac binary? What are the odds that any of this will
be added to the next version of the Ultra-Giganto Patch?
-Xplo
Date: 3 Nov 2000 01:04:09
Message: <3a025559$1@news.povray.org>
Chris Huff wrote in message ...
Yes.
That's going to be part of the system, since I can't do antialiasing with
just one pixel.
>>  etc.
I don't have it implemented yet, but this will be for the "poly" object
type.  It's much easier to enter a formula for a 7th-order polynomial as a
formula than as a string of a hundred coefficients.
Yes, render quality options.  I'm going to make it possible to turn specific
things on and off -- specifically, these will be available in version 0.2:
 +QQ = use quick colors
 +QA = use area lights -- cancels +QF
 +QF = use ambient only -- cancels +QA, +QM
 +QS = calculate shadows
 +QM = use reflection -- cancels +QF
 +QL = use refraction
 +QN = use normals
 +QV = use media?
>>  * Improved splines
This is going to be an improvement on the spline{} syntax.
Mark
Date: 3 Nov 2000 01:14:03
Message: <3a0257ab@news.povray.org>
Mark Wagner wrote in message
<8FE01D1B3markwagner17gtenet@204.213.191.228>...
A Windows binary is available at:
http://www.geocities.com/rengaw03/download/wskypov.zip
Mark
Date: 3 Nov 2000 04:06:42
Message: <3A02B82F.1A446F24@chesapeake.net>
I tried to use the link provided but geocities said
that page was not available. I tried .../rengaw03/download/
and HAL invited me to go back.
sniff..... I so wanted to see this version.... sniff
> Mark
Date: 3 Nov 2000 09:46:00
Message: <chrishuff-AE6B1C.09490803112000@news.povray.org>
In article <3a025559$1@news.povray.org>, "Mark Wagner"
> Yes.
I will send you the code as soon as it is tested.
> just one pixel.
Good. :-)
> object type.  It's much easier to enter a formula for a 7th-order
> polynomial as a formula than as a string of a hundred coefficients.
Oh, I thought this was for something else...this seems rather redundant,
since you can just use isosurfaces to do the same thing, and
often(usually?) with faster rendering.
Oh...
Ok, what improvements are you thinking of? More spline types, the
ability to choose what kind of spline to use at evaluation time?
By the second, I mean something like this:
#declare Spline = spline {...the usual spline stuff...}
#declare Val1 = Spline(XVal);
#declare Val2 = Spline(XVal, cubic_spline);
#declare Val3 = Spline(XVal, linear_spline);
Another wild idea that might be useful: allow splines to be used as
color maps. :-)
Date: 4 Nov 2000 00:41:54
Message: <3A03A18D.FDFBCBF0@peak.edu.ee>
Ditto
Margus Ramst
