POV-Ray : Newsgroups : povray.advanced-users : Fast volume rendering Server Time
22 Feb 2025 16:13:08 EST (-0500)
  Fast volume rendering (Message 1 to 5 of 5)
Subject: Fast volume rendering
Date: 23 Sep 2024 09:26:27
Message: <66f16c83$1@news.povray.org>
Hi all !
I am working on web GUI to Povray for volume visualization
applications, using 'media' and 'df3' format. The main idea is providing
the user with some fast WebGL-based gizmos (bounding box, grid,light
version of volume data) for fast camera positioning like here:
https://threejs.org/examples/?q=volume#webgl_volume_perlin
and then making server-side high-quality rendering like here:
https://povlab.online/?scene=dicom.pov
Can anyone suggest how to make volume rendering faster, but without
losing a quality ?
Thanks in advance.
YB
Subject: Re: Fast volume rendering
Date: 23 Sep 2024 10:25:00
Message: <web.66f1797c1b0021ea5a6be6925979125@news.povray.org>
yesbird <sya### [at] gmailcom> wrote:
> Hi all !
> losing a quality ?
> Thanks in advance.
> YB
Off the top of my head, POV-Ray's media would get approximated by a procedural
function that governed the rgb values based on the <x, y, z> coordinates, and so
whatever method that threejs uses, or Shadertoy ought to give decent results.
Reading in a df3 file would seem to be the only bottleneck.
Are you looking to make it faster than the examples you linked to?
Or are you looking to find a way to render 3D volumes in POV-Ray faster than
whatever methods you're currently using?
- BW
Date: 23 Sep 2024 11:14:23
Message: <66f185cf$1@news.povray.org>
Yes, this one.
I see the following workflow:
User is playing with the scene using three.js and then by
clicking "Render" button (or by releasing the mouse button) sends an SDL
scene, generated on-the-fly, to the server, getting a rendered image.
(Assuming that 'df3' data is already on the server).
The main goal is to make this cycle as fast as possible, ideally
achieving near-real-time performance. I am investigating 'media' with
'df3' deeply now, maybe there are some hidden tricks and/or parameters
will help ...
General idea is building the bridge between the WebGL/WebXR (three.js)
and Povray for different applications, like this future  math-museum:
https://math.povlab.online/
(inspired by https://virtualmathmuseum.org/)
BTW, behind the povlab.online now 128 virtual cores of:
AMD EPYC 7763 64-Core Processor
CPU MHz         : 2599.927
YB
Date: 23 Sep 2024 11:21:05
Message: <66f18761$1@news.povray.org>
Le 2024-09-23 à 09:26, yesbird a écrit :
> Hi all !
> losing a quality ?
> Thanks in advance.
> YB
The type of media used have a lot of effect. A media can be emissive,
absorbing or scattering.
Emissive media renders the fastest. They work better against a dark
background. They add to the background. They never cast any shadow and
never interact with any light_source.
Absorbing media is a close second. Work better against a light
background. They subtract from the background. They do cast shadows when
there is some light_source present. Lights never illuminate them.
Scattering media are the slowest. They need a light source that interact
with them. They subtract from the background, when there is a light,
they also add to the background.
Use the default sampling method 3. NEVER use an intervals value larger
than the default of 1, increase the sample value instead. More intervals
can cause glitches and is MUCH slower. intervals 10 samples 10 is at
least 5 times slower than just samples 200 for half the samples.
Date: 23 Sep 2024 11:36:41
Message: <66f18b09$1@news.povray.org>
Thank you very much for detailed explanation and useful suggestions -
you saved me a lot of time, while I am still have a space for
interesting experiments with media :).
YB
