POV-Ray : Newsgroups : povray.advanced-users : Location changing while scaling Server Time
20 May 2025 00:15:07 EDT (-0400)
  Location changing while scaling (Message 1 to 3 of 3)
Subject: Location changing while scaling
Date: 2 Sep 2024 05:39:26
Message: <66d587ce@news.povray.org>
Hi, all !
While playing with meshes I've encountered strange behavior of spheres,
positioned at mesh vertices - after changing the scale they move from
previous location (see images). Looks like the scale
operation applied to a whole array of spheres, produced by loop, but the
scale operator is inside the sphere object. I expected they would stay
in place and only change the size.
What I'm missing ? Any suggestions please ...
YB
#version 3.8;
   perspective
   angle 25
   location  <20,15,20> * 0.2
   look_at   <0.5,0.5,0>
   right x * image_width / image_height
light_source{<-500,0,0> rgb 1} light_source{<500,0,0> rgb 1}
light_source{<0,0,-500> rgb 1} light_source{<0,0,500> rgb 1}
light_source{<20,15,20> rgb 0.4}
#declare VertexVectors= array[24] {
   <0,0,0>, <0.5,0,0>, <0.5,0.5,0>, //1
   <0.5,0,0>, <1,0,0>, <0.5,0.5,0>, //2
   <1,0,0>, <1,0.5,0>, <0.5,0.5,0>, //3
   <1,0.5,0>, <1,1,0>, <0.5,0.5,0>, //4
   <1,1,0>, <0.5,1,0>, <0.5,0.5,0>, //5
   <0.5,1,0>, <0,1,0>, <0.5,0.5,0>, //6
   <0,1,0>, <0,0.5,0>, <0.5,0.5,0>, //7
   <0,0.5,0>, <0,0,0>, <0.5,0.5,0>  //8
// Mesh
mesh2 {
    #local len = dimension_size(VertexVectors,1);
    vertex_vectors {
       len,
   		#for (i, 0, len-1)
     		VertexVectors[i]
    face_indices {
       8,
       <0,1,2>,    <3,4,5>,       //1 2
       <6,7,8>,    <9,10,11>,     //3 4
       <12,13,14>, <15,16,17>,    //5 6
       <18,19,20>, <21,22,23>     //7 8
    pigment {rgb 1}
// Spheres
#local len = dimension_size(VertexVectors,1) - 1;
#for (i, 0, len)
   sphere { VertexVectors[i], 0.04
            texture { pigment {rgb <0.1, 0.3, 0.1>} }
            scale y * 1.2 // Why they moves ?
Download 'test_scale_no.png' (12 KB) Download 'test_scale_yes.png' (12 KB)
Preview of image 'test_scale_no.png'
Preview of image 'test_scale_yes.png'
Subject: Re: Location changing while scaling
Date: 2 Sep 2024 06:43:39
Message: <66d596db$1@news.povray.org>
Le 2024-09-02 à 05:39, yesbird a écrit :
> Hi, all !
> YB
> #version 3.8;
> camera {
>    perspective
>    angle 25
>    look_at   <0.5,0.5,0>
> // Mesh
> mesh2 {
>     vertex_vectors {
>        len,
>            #for (i, 0, len-1)
>              VertexVectors[i]
>            #end
>     face_indices {
>        8,
>     pigment {rgb 1}
> // Spheres
> #for (i, 0, len)
> #end
The scale is applied relative to the origin of the coordinate system,
not to the centre of the object.
That mean that the centre of your spheres are scaled.
You need to scale your spheres when they are at <0,0,0> then translate
them to the desired location.
Use this instead :
// Spheres
#for (i, 0, len)
   sphere { 0, 0.04 scale y * 1.2 // No longer move
	translate VertexVectors[i]
Date: 2 Sep 2024 07:04:37
Message: <66d59bc5$1@news.povray.org>
> Use this instead :
> // Spheres
> #for (i, 0, len)
Many thanks for elegant solution !
YB
