POV-Ray : Newsgroups : povray.advanced-users : Applying noise to geometry Server Time
10 Oct 2025 07:05:20 EDT (-0400)
  Applying noise to geometry (Message 1 to 10 of 17)
Subject: Applying noise to geometry
Date: 27 Feb 2023 13:32:57
Message: <63fcf759@news.povray.org>
while working on Yes-project, I am trying to find the way of making
the objects less 'geometrical', giving them more natural and 'noisy'
shapes (like in this attachment, for example). The only way I found in
manual is to play with normals, but I'd like to have an influence on
geometry, to apply more relief.
It's possible to pass a noisy hi-res mesh from ZBrush, as I'm doing now,
but this is not 'pure' POV-way and import takes some 'non-zero' time.
Maybe anyone can advise something about such arbitrary geometry
modifications ?
Thanks in advance.
YB
Download 'spral_path.png' (386 KB)
Preview of image 'spral_path.png'
Subject: Re: Applying noise to geometry
Date: 27 Feb 2023 14:15:00
Message: <web.63fd01122d72758917bac71e8ffb8ce3@news.povray.org>
If you create your mesh with macros you can use (noise)functions to displace
vertices of the mesh. Here an example using crackle pattern for displacement.
#version 3.8;
#include "meshmaker.inc"
global_settings {assumed_gamma 1.0}
   location  <0,1,-10>
   look_at   <0,0,0>
   angle 20
light_source { <500,500,-500> rgb <1,0.9,0.8> }
light_source { <-100,100,-500> rgb <0.3,0.3,0.5> }
#declare Crack= function {
    crackle
    colour_map{
      [0, rgb .01]
      [1, rgb .05]
    scale 0.05
#declare R= function(u,v) {
  Crack(u,v,0).gray * 5
#declare F1= function(u,v){(.5+R(u,v))*cos(u)}
#declare F2= function(u,v){(.5+R(u,v))*sin(u)}
#declare F3= function(u,v){v - R(u,v)}  // pull the spikes up
object{
   Parametric(
      F1, F2, F3,
      <0, -1>,
      <2*pi, 1>,
      500, 500, ""
   uv_mapping
   pigment{rgb 1}
   finish{specular 0.5}
   rotate <60,0,0>
ingo
Date: 27 Feb 2023 14:30:00
Message: <web.63fd03fb2d72758917bac71e8ffb8ce3@news.povray.org>
> modifications ?
> Thanks in advance.
Another method could be to use the trace function to place objects on other
objects. You could cover an object with 'random' sized small blobs to get an
effect like your example. It is the same method as used for creating forests and
grass patches in landscapes.
ingo
Date: 27 Feb 2023 14:52:06
Message: <df22d77a-a8fc-3405-b44f-a225da3dda01@gmail.com>
Hi ingo,
thanks for ideas and examples. Although fist method works fine, second
looks more attractive, as, I suppose, will allow 'decorate' imported
mesh, which gives me more control on the object's shape.
Unfortunately, I can't find a more detailed description and/or examples.
Could you please point me to them ?
YB
Date: 27 Feb 2023 15:13:43
Message: <84be26af-b5dc-6c8a-4a96-f89059e63a19@gmail.com>
> YB
Found it now:
http://news.povray.org/povray.binaries.tutorials/message/%3Cweb.51f61e827603294573fc9ebb0%40news.povray.org%3E/#%3Cweb.51f61e827603294573fc9ebb0%40news.povray.org%3E
YB
Date: 27 Feb 2023 17:26:05
Message: <63fd2dfd$1@news.povray.org>
>> other
>> get an
>> forests and
> Hi ingo,
I haven't tried it out for myself, but there is an Object Collection
module that might be helpful for this method:
https://github.com/LeForgeron/PovContributions/tree/master/findsurface/maggot%201.0
Date: 27 Feb 2023 18:43:37
Message: <2519ca7c-3804-d941-50de-b664a19ab119@gmail.com>
Thanks a lot, this is exactly what I was expected !
It works fine, I need only to play with covering object's orientation a
little.
YB
Download 'findsurface.png' (315 KB)
Preview of image 'findsurface.png'
Date: 27 Feb 2023 19:10:00
Message: <web.63fd45ba2d7275891f9dae3025979125@news.povray.org>
> little.
> YB
I haven't looked any of this over, but look over this thread, and see if any of
that helps you:
http://news.povray.org/povray.binaries.images/message/%3Cweb.603d82a3a906d8e31f9dae300%40news.povray.org%3E/#%3Cweb.603
-BW
Date: 27 Feb 2023 19:28:55
Message: <509e7f25-9981-680f-2c96-07e945f03104@gmail.com>
> that helps you:
Thanks, Bald, I will try it...
"Curiouser and curiouser!"
YB
Date: 28 Feb 2023 02:00:00
Message: <web.63fda6072d72758917bac71e8ffb8ce3@news.povray.org>
I.i.r.c. Poseray https://sites.google.com/site/poseray/ can do mesh displacement
based on uv vectors and images. Never tried it myself.
ingo
