POV-Ray : Newsgroups : povray.advanced-users : Does wrapping atan2(0,0) avoid the domain error? Server Time
10 Oct 2025 00:28:02 EDT (-0400)
  Does wrapping atan2(0,0) avoid the domain error? (Message 1 to 5 of 5)
Subject: Does wrapping atan2(0,0) avoid the domain error?
Date: 5 Dec 2022 14:49:00
Message: <638e4b2c$1@news.povray.org>
I have a situation where it is possible to pass zero as both arguments
to atan2(), which is the one case where the function fails.  But while
attempting to find a workaround for this situation, I discovered that
simply calling atan2(0,0) from within a user-defined function avoids the
domain error!
I don't know whether this is intended POV-Ray behavior or just a fluke
of my computer OS.
Can you all try the following scene file with -F and report what the
message window says, along with your operating system and POV version?
My system writes 0.000000 for the first line, and fails on the second.
I'd like to know if this is consistent behavior across all operating
systems.  Or perhaps Chris or Thorsten can tell us if this is intended
behavior?
----------[BEGIN CODE]----------
#version max (3.5, min (3.8, version));
#declare fn_Atan2 = function (y, x) { atan2 (y, x) }
#debug concat ("atan2 (0,0) with wrapper = ", str (fn_Atan2 (0,0), 0,
6), "\n")
#debug concat ("bare atan2 (0,0) = ", str (atan2 (0,0), 0, 6), "\n")
-----------[END CODE]-----------
Subject: Re: Does wrapping atan2(0,0) avoid the domain error?
Date: 5 Dec 2022 15:15:00
Message: <web.638e5098dfb43945c0ce110b6cde94f1@news.povray.org>
hi,
> Can you all try the following ...
POV-Ray 3.7.0.8.unofficial
atan2 (0,0) with wrapper = 0.000000
File 'cr.pov' line 6: Parse Error: Domain error in atan2!
regards, jr.
Date: 5 Dec 2022 19:30:00
Message: <web.638e8c31dfb439454829143889db30a9@news.povray.org>
> domain error!
> of my computer OS.
Hi Ricky
I recommend that you don't make you code rely on a missing domain error.
(That it is missing could be considered a bug.)
Instead, I suggest that you write a function that deals with the
problematic values explicitly. E.g. like this:
#declare Atan2_Fn =
    function(y, x) {
        select(
            y,
            atan2(y, x),
            select(
                x,
                atan2(y, x),
                0,  // Insert the result you want for Atan2_Fn(0, 0)
                atan2(y, x)
            atan2(y, x)
- or like this if you want 0 returned for AltAtan2_Fn(0, 0):
#declare AltAtan2_Fn =
    function(y, x) {
        atan2(
            y,
            select(
                x,
                x,
                select(
                    y,
                    x,
                    1,
                    x
                x
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 9 Dec 2022 12:36:11
Message: <6393720b$1@news.povray.org>
> domain error!
> of my computer OS.
> behavior?
> 6), "\n")
Further details here :
<http://news.povray.org/povray.general/thread/%3C616bfd9d%241%40news.povray.org%3E/?ttop=438714&toff=50>
Kurtz le pirate
Compagnie de la Banquise
Date: 14 Dec 2022 12:21:13
Message: <639a0609$1@news.povray.org>
Yes, and it was the part about atan2(0,0) being different on different
systems that I'm leery about.  But it makes sense that there would be no
consistency; any angle at all would satisfy (0,0).
