POV-Ray : Newsgroups : povray.advanced-users : Correct function/pigment syntax? Server Time
10 Oct 2025 00:26:48 EDT (-0400)
  Correct function/pigment syntax? (Message 1 to 4 of 4)
Subject: Correct function/pigment syntax?
Date: 13 May 2021 18:19:05
Message: <609da5d9@news.povray.org>
I am trying to combine pigments and functions in different ways. Here is
an example:
#declare pigment_1 = pigment
	slope {+y}
	color_map
		[0 rgb 0]
		[1 rgb 1]
#declare function_1 = function {pigment {pigment_1}}
#declare pigment_2 = pigment {function {function_1(x,y,z)}
But I am getting a parse error on pigment_2. What is the correct syntax
to get this example to work?
Mike
Subject: Re: Correct function/pigment syntax?
Date: 13 May 2021 18:31:04
Message: <609da8a8$1@news.povray.org>
See my post in p.t.s-f
> an example:
>      slope {+y}
>      color_map
>          [0 rgb 0]
>          [1 rgb 1]
> Mike
Date: 13 May 2021 19:10:00
Message: <web.609db1172fe55fc21f9dae3025979125@news.povray.org>
You don't have to use the x, y, z until you actually evaluate the function for
something.
So you should just be able to do:
#declare pigment_2 = pigment {function {function_1}}
Also, test_clu.pov ran for 6:45, and I halted it, as it was still parsing away
like mad.  You must have quite a system if you did it in 2:20.
Maybe just attach your completed render?
Date: 13 May 2021 19:33:33
Message: <609db74d$1@news.povray.org>
> something.
I found what I was looking for here:
http://news.povray.org/povray.newusers/thread/%3C5473da29%40news.povray.org%3E/
But I cannot get it to produce anything other than rgb <0,0,0> in the
render. See p.t.s-f.
I got this all to work. Will update the other thread later.
Mike
