POV-Ray : Newsgroups : povray.advanced-users : write uint32_t Server Time
4 Nov 2026 17:31:19 EST (-0500)
  write uint32_t (Message 1 to 15 of 15)
Subject: write uint32_t
Date: 29 Mar 2021 09:35:59
Message: <XnsACFC9EABB33B7seed7@news.povray.org>
The fine documentation states: "Note: Currently, unsigned 32-bit words are
not supported."
Guess what. I need those.
Is there some trickery with 4 uint8' or 2 uint16le's to get the proper
bytes in the proper place?
TIA,
Ingo
Subject: Re: write uint32_t
Date: 29 Mar 2021 12:34:02
Message: <6062017a$1@news.povray.org>
> not supported."
For what feature/functionality ?
When writing files I'm not aware of any 32bit write / per channel
capability today in any official version of POV-Ray. If storing values
doubles give you effectively more than 32bits of depth - at the cost of
doubles.
Bill P.
Date: 29 Mar 2021 12:57:55
Message: <XnsACFCC0E88F585seed7@news.povray.org>
Sorry Bill. I wasn't very clear. For "3.3.2.3.4 The write Directive". It
supports:
sint32be, sint32le - signed 32-bit word (-2^31..2^31-1)
but not uint32.
Ingo
Date: 29 Mar 2021 13:13:02
Message: <60620a9e$1@news.povray.org>
 > supports:
 > but not uint32.
You can just compute the ones' complement inverse before output, and you
get what you want ;-)
Thorsten
Date: 29 Mar 2021 13:15:34
Message: <60620b36$1@news.povray.org>
> supports:
> but not uint32.
You can just compute the two's complement inverse before output, and you
get what you want
Thorsten
Date: 29 Mar 2021 13:25:35
Message: <XnsACFCC59E163CDseed7@news.povray.org>
> you get what you want
Sorry Thorsten, I realy don't understand. Can we do it by example.
I have a number, 4321 and it hast to written to a file as uint_32.
Ingo
Date: 29 Mar 2021 13:35:00
Message: <web.60620e7f8cf934b8ae6f04a89db30a9@news.povray.org>
> not supported."
Hi Ingo
You can try this:
#version 3.7;
#declare AnInteger = 4091728320; // 0xf3e2d1c0
#declare R = AnInteger;
#declare Byte_0 = mod(R, 256);
#declare R = div(R, 256);
#declare Byte_1 = mod(R, 256);
#declare Byte_2 = mod(R, 256);
#declare Byte_3 = mod(R, 256);
#fopen SomeFile "LitteEndian.bin" write
#write (SomeFile, uint8 Byte_0)
#write (SomeFile, uint8 Byte_1)
#write (SomeFile, uint8 Byte_2)
#write (SomeFile, uint8 Byte_3)
#fclose SomeFile
#fopen SomeFile "BigEndian.bin" write
#fclose SomeFile
#error "Finished"
You can upload the resulting files to this web page: https://hexed.it
- and then inspect the results as both big endian and little endian integeres.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 29 Mar 2021 13:45:00
Message: <web.606211058cf934b81f9dae3025979125@news.povray.org>
If you get any of that to work, I would like a very small working code snippet
to paste into my collection of Keyword Examples.
Computing complement inverses would be a nice trick to add in as well.
I'm sticking to the stuff I know how to do already, and saving the "need to
learn that" stuff until later/last.
Date: 29 Mar 2021 13:45:38
Message: <XnsACFCC9042258Fseed7@news.povray.org>
in news:web.60620e7f8cf934b8ae6f04a89db30a9@news.povray.org Tor Olav
Thank you Tor Olav!
Ingo
Date: 29 Mar 2021 14:00:00
Message: <web.606214ce8cf934b81f9dae3025979125@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> You can try this:
Leave it to you to post a full code example before I even finished typing my
request  :D  (He's too fast for me, folks.)
That ought to give me some more interesting material for div and mod as well.
Thanks for keeping the info flowing - there's always something new to learn.
Date: 29 Mar 2021 16:45:00
Message: <web.60623c1a8cf934b8ae6f04a89db30a9@news.povray.org>
> > You can try this:
Then perhaps I started before you ;)
If you want to try to do something along the way Thorsten suggested, here's some
code to start with:
#version 3.7;
#declare UnsignedInteger = 4091728320; // 0xf3e2d1c0
#debug "\n\n"
#debug str(UnsignedInteger, 0, 0)
#debug "\n"
#declare NoOfBits = ceil(ln(UnsignedInteger)/ln(2));
#declare TheBits = array[NoOfBits];
#declare R = UnsignedInteger;
#for (I, 0, NoOfBits-1)
    #declare TheBits[I] = mod(R, 2);
    #declare R = div(R, 2);
#end // for
#declare N = 0;
#for (I, NoOfBits-1, 0, -1)
    #declare InvertedBit = 1 - TheBits[I];
    #declare N = 2*N + InvertedBit;
#end // for
#debug str(N, 0, 0) // 203238975 = 0x0C1D2E3F
#debug "\n\n"
#error "Finished"
If you get to a point where you need to mask away all other bits than the lower
32 your can do this:
#declare N = mod(N, pow(2, 32));
Tor Olav
http://subcube.com
Date: 30 Mar 2021 03:04:52
Message: <6062cd94$1@news.povray.org>
Unsigned is only relevant when dealing with numbers past 2**31, so you
can just write it as signed.
Thorsten
Date: 30 Mar 2021 03:24:32
Message: <6062d230$1@news.povray.org>
It should be (untested):
#declare uint32 = function(x) { select(x-2147483648, x, x-4294967296) }
Thorsten
Date: 30 Mar 2021 06:48:01
Message: <XnsACFD823568867seed7@news.povray.org>
It's a field in a header file describing the data length in it. The
maximum length can be up to 2^32. Hence the unint32 question regardless of
the actual data length.
Thanks Thorsten,
Ingo
Date: 30 Mar 2021 09:15:00
Message: <web.6063231a8cf934b8ae6f04a89db30a9@news.povray.org>
Here's how you can do it with sint32le and sint32be. This does it like Thorsten
indicated in his last post.
#version 3.7;
// #declare UnsignedInteger = 0; // 0x00000000
// #declare UnsignedInteger = 1; // 0x00000001
// #declare UnsignedInteger = pow(2, 31) - 1; // 0x7FFFFFFF
// #declare UnsignedInteger = pow(2, 31); // 0x80000000
// #declare UnsignedInteger = pow(2, 31) + 1; // 0x80000001
// #declare UnsignedInteger = pow(2, 32) - 1; // 0xFFFFFFFF
#declare UnsignedInteger = 4321; // 0x000010E1
// #declare UnsignedInteger = 1059986700; // 0x3F2E1D0C
// #declare UnsignedInteger = 4091728320; // 0xF3E2D1C0
#if (UnsignedInteger < pow(2, 31))
    #declare N = UnsignedInteger;
#else
    #declare N = UnsignedInteger - pow(2, 32);
#end // if
#debug concat("\n\n", str(N, 0, 0), "\n\n")
#fopen SomeFile "LitteEndian32.bin" write
#write (SomeFile, sint32le N)
#fclose SomeFile
#fopen SomeFile "BigEndian32.bin" write
#write (SomeFile, sint32be N)
#fclose SomeFile
#error "Finished"
Tor Olav
http://subcube.com
