POV-Ray : Newsgroups : povray.advanced-users : Speeding up media Server Time
25 May 2026 10:34:32 EDT (-0400)
  Speeding up media (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Speeding up media
Date: 14 Feb 2021 12:32:56
Message: <60295ec8$1@news.povray.org>
Le 2021-02-14 à 11:02, Ash Holsenback a écrit :
> another question: are variance, confidence and ratio valid in method
> 3... given current narrative i'd say yes to the first two and no on the
> last
> made some progress... here's what i have so far
> http://wiki.povray.org/content/Reference:Sampling_Parameters_%26_Methods
The confidense and ratio are to adjust the samples numbers between the
various intervals and are not used.
As for variance, it also seems to be method 1 and 2 specific. It don't
seems to have any effect when using method 3.
Date: 14 Feb 2021 14:33:04
Message: <60297af0$1@news.povray.org>
>> the last
are you sure about that... given that the narrative after Sampling
Method 3: uses the term variance, then later on in the narrative in
Sampling method 1: last paragraph ( above the note ) links variance and
confidence together... did i make a bad leap? the role of ratio is a
couple of paragraphs up... please expand on this a bit ;-)
Date: 14 Feb 2021 14:38:42
Message: <60297c42@news.povray.org>
>>> the last
one more thing... would it be accurate to say that most if not all those
media related keywords work for all three methods, however some of their
roles have changed.
Date: 15 Feb 2021 02:37:16
Message: <602a24ac@news.povray.org>
Op 14/02/2021 om 20:38 schreef Ash Holsenback:
>>>> the last
>>> the various intervals and are not used.
>>> don't seems to have any effect when using method 3.
>> and confidence together... did i make a bad leap? the role of ratio is
>> a couple of paragraphs up... please expand on this a bit ;-)
> roles have changed.
Give that man a beer!
Much better assuredly.
Pending more learned answers on your last question, I would be wary to
affirm this. The point being probably - if those are silently ignored by
method 3 as Alain states - that people will wring themselves into hoops
only to see some 'improvements' to their media, without any results
obviously. If, on the other hand, those are /not/ ignored, we need to be
dead sure about it. What does the code say, Mr Pokorny?
Date: 15 Feb 2021 06:00:30
Message: <602a544e$1@news.povray.org>
Generally, I recommend we make the recommendation to use only media 3
more strongly. Using the other methods with the current code base is
potentially confusing given they won't get some of the normal defaults
due how the flip to method 3 was done in the parsing phase.
I agree with Alain. The keywords: confidence, variance and ratio are
used only with methods 1 and 2 (a). The use of the variance word in the
method 3 wording is I suppose correct, but unfortunate. Another sample
is taken between two existing, if the difference between the two end
samples is > the aa_threshold.
(a) For the purposes of documentation see (a1) and ignore the rest of
this footnote. Someone can set the intervals in method 3 to more than 1
and if they do ratio does come into play with a lit and un-lit intervals
scheme internally which 'probably' doesn't have much of an end effect
for method 3, but... Always true, sometimes, almost never, never? Not
sure... When using multiple medias with mixed sampling types, I know of
some bleed through in the keyword settings between methods.
(a1) It would be good to somewhere add a note along the lines of: When
using multiple medias, it's strongly recommend all use the same sampling
method. With the current code there is some keyword setting bleed
between methods.
Aside: The sentence about monte carlo.... only applies to methods 1 and 2.
Aside: FWIW. In povr I plan to at least make it appear methods 1 & 2 and
their keywords do not exist at all (and I'll pull jitter from media 3).
Ideally, I'll replace the whole of the current implementation with a new
media 3 like one. There are standing issue with media 3 too with respect
to speed, accuracy of result and when and if adaptive sampling actually
kicks in. But, it's media - which is fuzzy. Most remaining issues don't
matter much to an end result as I recall - so long as we sample enough
that things look good. ;-)
Bill P.
Date: 15 Feb 2021 12:39:57
Message: <602ab1ed$1@news.povray.org>
>> by method 3 as Alain states - that people will wring themselves into
>> hoops only to see some 'improvements' to their media, without any
>> results obviously. If, on the other hand, those are /not/ ignored, we
>> need to be dead sure about it. What does the code say, Mr Pokorny?
> between methods.
> Bill P.
thanks /everyone/ for guidance and support... please review
Date: 15 Feb 2021 18:58:20
Message: <602b0a9c$1@news.povray.org>
> Bill P.
This probably explain why using several intervals bog down method 3 so
much. It tries to compute ratios and variances when it's not needed.
Date: 16 Feb 2021 02:36:33
Message: <602b7601$1@news.povray.org>
Op 15/02/2021 om 18:39 schreef Ash Holsenback:
>>> to affirm this. The point being probably - if those are silently
>>> ignored by method 3 as Alain states - that people will wring
>>> themselves into hoops only to see some 'improvements' to their media,
>>> without any results obviously. If, on the other hand, those are /not/
>>> ignored, we need to be dead sure about it. What does the code say, Mr
>>> Pokorny?
>> the method 3 wording is I suppose correct, but unfortunate. Another
>> sample is taken between two existing, if the difference between the
>> two end samples is > the aa_threshold.
>> 1 and if they do ratio does come into play with a lit and un-lit
>> intervals scheme internally which 'probably' doesn't have much of an
>> end effect for method 3, but... Always true, sometimes, almost never,
>> never? Not sure... When using multiple medias with mixed sampling
>> types, I know of some bleed through in the keyword settings between
>> methods.
>> sampling method. With the current code there is some keyword setting
>> bleed between methods.
>> and 2.
>> and their keywords do not exist at all (and I'll pull jitter from
>> media 3). Ideally, I'll replace the whole of the current
>> implementation with a new media 3 like one. There are standing issue
>> with media 3 too with respect to speed, accuracy of result and when
>> and if adaptive sampling actually kicks in. But, it's media - which is
>> fuzzy. Most remaining issues don't matter much to an end result as I
>> recall - so long as we sample enough that things look good. ;-)
>> Bill P.
Yes. Add that note (a1) from Bill. That is important indeed. One trivial
thing I want to suggest: Add an empty line between Methods. It would
increase the readability even more.
[Maybe Alain will not have to repeat indefinitely anymore about method
3, intervals 1, and single samples.... ;-) ]
Date: 17 Feb 2021 08:23:18
Message: <602d18c6$1@news.povray.org>
>> methods.
>> Bill P.
Only ratios(a) I believe, but yes, expect this a part of the typical
slow down (always? sometimes not?). I don't understand all the whys.
The most obvious reason is the number of interval acts as a multiplier
for the starting number of samples with method 3 and this is 10.
(a) and the underlying light interval stuff. This code is tied to light
types. My guess is it's aimed at speeding up (or better resolving
perhaps?) spotlights and cylindrical lighting when using media(a1).
Maybe it all more or less works - but I have doubts about how well
beyond the simplest test set ups. I'd like to pull all the lit/unlit
interval code out too.
Bill P.
Date: 17 Feb 2021 11:40:01
Message: <602d46e1$1@news.povray.org>
>>> methods.
>>> Bill P.
> Bill P.
In my testings, intervals 5 samples 10 run MUCH slower than samples 100
and default intervals 1.
