How do I calculate the distance between a point and the camera? Except,
I am using an orthographic camera, so I really need the distance between
a point and the plane formed by the camera's up and right vectors.
Here's my camera definition. Thanks.
Mike
#declare Camera_Diagonal = cosd(45);
#declare Camera_Aspect = image_height / image_width;
#declare Camera_Width = 10240; // was 7680 * 4/3
#declare Camera_Vertical = 225; // was 225
#declare Camera_Horizontal = 30;
#declare Camera_Distance = Camera_Width;
#declare Camera_Up = -y * Camera_Diagonal * Camera_Width * Camera_Aspect;
#declare Camera_Right = +x * Camera_Diagonal * Camera_Width;
#declare Camera_Location = -z * Camera_Distance;
#declare Camera_Direction = +z * Camera_Distance;
#declare Camera_LookAt = Camera_Location + Camera_Direction;
#declare Camera_Rotate = <-Camera_Horizontal,Camera_Vertical,0,>;
#declare Camera_Scale = 4;
#declare Camera_Translate = <0,0,0>;
#declare Camera_Transform = transform
rotate Camera_Rotate
scale Camera_Scale
translate Camera_Translate
camera
orthographic
up Camera_Up
right Camera_Right
location Camera_Location
direction Camera_Direction
transform {Camera_Transform}
#declare Camera_Location = vtransform(Camera_Location,Camera_Transform);
#declare Camera_LookAt = vtransform(Camera_LookAt,Camera_Transform);
VDist(V1, V2). Compute the distance between two points.
Parameters:
V1, V2 = Input vectors.
http://www.povray.org/documentation/view/3.7.1/459/
So, you could either compute the distance between the Camera_Transform[ed]
Camera_Location and Camera_LookAt, or since IIRC the default camera uses a
projection plane one POV-unit away from the camera, you could normalize that and
multiply it by the length of the Camera_Distance vector...
Or you could use a Graphics Gems macro to actually calculate the shortest
(perpendicular) distance between the (transformed) camera point and the
(transformed) up-right plane.
Subject: Re: Calculate distance between point and viewport
Date: 23 Feb 2020 14:55:01
Message: <5e52d895@news.povray.org>
> Parameters:
No, the first point is somewhere in space and is not connected to the
camera.
The plane doesn't actually have to be the up-right plane exactly, but it
does need to be parallel to it and lie somewhere beyond the extents of
the model.
Mike
> camera.
OK - that's just the plane equation, IIRC: Ax+By+Cz-D = 0
Also in F. Lohmueller's analytical geometry include file (Insert Menu?)
and you just set the "offset" from the origin with D.
same as you'd do with plane {z, D}
Then you calculate the distance of the point from that plane.
http://news.povray.org/povray.binaries.images/message/%3Cweb.5880fc4d1652a4dcc437ac910%40news.povray.org%3E/#%3Cweb.588
> the model.
That's confusing, since usually the image projection plane is "in front of" all
the stuff - between the camera and the "model", not "beyond the extents" of it.
But I think the link gives you exactly what you need.
