POV-Ray : Newsgroups : povray.advanced-users : Get Euler angles from unit vector? Server Time
27 Mar 2026 21:09:58 EDT (-0400)
  Get Euler angles from unit vector? (Message 11 to 13 of 13)
Subject: Re: Get Euler angles from unit vector?
Date: 28 Sep 2018 00:36:03
Message: <5badafb3$1@news.povray.org>
Awesome, thanks!
On 9/28/2018 12:27 AM, clipka wrote:
> Am 28.09.2018 um 03:27 schrieb Mike Horvath:
>> Two important questions I have (that may not be explained in the docs),
>> is how to convert a 3x3 rotation matrix to POV-Ray syntax, and how to
>> determine the inverse matrix?
> given a matrix
>       / a  b  c \
>      (  d  e  f  )
>       \ g  h  i /
> you have to specify either
>      matrix < a, b, c,
>               d, e, f,
>               g, h, i,
>               0, 0, 0 >
> or
>      matrix < a, d, g,
>               b, e, h,
>               c, f, i,
>               0, 0, 0 >
> The order depends on whether the original matrix is specified in
> "mathematical" or "computer graphics" style - they're mirrored along the
> diagonal. Can't remember which one POV-Ray uses.
> Determining the inverse /transformation/ is simple:
>      #declare Foo = transform { matrix < ... > }
>      #declare FooInv = transform { Foo inverse }
> Actually getting at the corresponding matrix is possible by applying the
> inverted transformation to the axis vectors.
Date: 28 Sep 2018 02:42:18
Message: <5badcd4a$1@news.povray.org>
> Mike
you only have to input a 3x4 ( column x line), but the math beyond use a
4x4 matrix with a fourth column set to
{ 0,
   0,
   0,
   1 }
(the 4x4 is important, when combining transformation, a 4x4 * 4x4 ->
4x4, whereas it make no sense with 3x4 )
The fourth line is the translation
http://wiki.povray.org/content/Reference:Transformations#Matrix
To input a 3x3 rotation matrix
( A B C
   D E F
   G H I )
into povray, it's "simply"
( A B C
   D E F
   G H I
   0 0 0 )
With A to I being the naughty variations of
"cos(phi)*sin(theta)*cos(gamma)" as usual.
To get the inverse matrix, I'm lazy:
#declare Forward = transform { matrix < .... > } };
#declare Backward = transform { Forward inverse };
As long as the forward matrix is not degenerated, that should do the job.
Date: 28 Sep 2018 02:53:23
Message: <5badcfe3$1@news.povray.org>
Le 28/09/2018 à 01:40, Mike Horvath a écrit :
> It would be nice to be able to set vector components like this:
>      #local tPrjB1.z = max(min(tPrjB1.z,1),-1);
> Are there any plans to do this in the future?
> Mike
you could use the following:
#local P = <p.x, P.y, max(min(P.z),1),-1)>;
Make that a set of macro, and voila.
#macro BoundZ( V )
<V.x, V.y, max(min(V.z),1),-1) >
#local P = BoundZ(P);
