POV-Ray : Newsgroups : povray.advanced-users : Calculating planet positions Server Time
16 May 2026 16:24:19 EDT (-0400)
  Calculating planet positions (Message 1 to 10 of 25)
Subject: Calculating planet positions
Date: 15 Sep 2018 13:07:46
Message: <5b9d3c62$1@news.povray.org>
I'm trying to adapt the following PDF to POV-Ray code for my
planetarium/orrery.
https://ssd.jpl.nasa.gov/txt/aprx_pos_planets.pdf
How do I calculate the modulus -180 <= M <= +180?
Is it equal to this?
	mod(number+180,360)-180
Mike
Subject: Re: Calculating planet positions
Date: 15 Sep 2018 14:15:07
Message: <web.5b9d4b5dfda659e4458c7afe0@news.povray.org>
> planetarium/orrery.
It was a gigantic PITA
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.5915a4387de46d5ec437ac910%40news.povray.org%3E/?mtop=41
6271
Even more of a PITA was unpacking date codes.
I don't know what that means
Date: 15 Sep 2018 15:03:32
Message: <5b9d5784$1@news.povray.org>
> planetarium/orrery.
180 degrees, really ?
Can't they use a decent measure of angle, in Grades !
Probably, as long as number is above -180 at start.
I never understood mod of negative value, and there might be divergent
definitions.
They seem to be using a referential for M to describe a full "circle",
so yes, they want to reduce the range of M to be between -180 and +180.
> Mike
Date: 15 Sep 2018 15:06:51
Message: <5b9d584b$1@news.povray.org>
>> planetarium/orrery.
> 6271
Interesting. It seems I posted in that thread too.
Quote:
"Modulos the mean anomaly so that -180 <= M <= +180 ..."
Mike
Date: 15 Sep 2018 16:15:00
Message: <web.5b9d6796fda659e4458c7afe0@news.povray.org>
Yes.   :D
> Quote:
5 sec search yielded:
https://lite.qwant.com/?q=""modulus+the+mean+anomaly
https://math.stackexchange.com/questions/1325434/modulus-to-a-range-x-to-x
I do believe that this is typically done with a macro, and occurs in the POV-Ray
source code.
#macro Modulate (_X)
     #while (_X < 180) #local _X = _X+360; #end
     #While (_X > 180) #local _X = _X-360; #end
     _X
type of thing.
Then of course, there's
http://www.povray.org/documentation/view/3.6.2/458/
clamp(V, Min, Max). A function that limits a value to a specific range, if it
goes outside that range it is "clamped" to this range, wrapping around. As the
input increases or decreases outside the given range, the output will repeatedly
sweep through that range, making a "sawtooth" waveform.
Parameters:
V = Input value.
Min = Minimum of output range.
Max = Maximum of output range.
Bill
Date: 15 Sep 2018 19:03:19
Message: <5b9d8fb7$1@news.povray.org>
Am 15.09.2018 um 22:12 schrieb Bald Eagle:
> source code.
>      _X
> #end
That would be way too time-consuming for very large or very small values.
> Parameters:
That'll indeed do it:
    #include "math.inc"
    #local Foo = clamp(M,-180,180);
Alternatively:
    #local Foo = mod(M+180,360)-180;
    #if (Foo < -180)
      #local Foo = Foo + 260;
The post-processing `#if` branch is necessary because mod(X,Y) wraps
positive values into the range [0..Y), but negative values into the
range (-Y..0].
[At least on platforms where converting a floating-point number to an
integer rounds towards 0. That's the case for all contemporary platform
I'm aware of, and is an official prerequisite for compiling POV-Ray, but
the C++ standard would also allow for rounding towards negative infinity
instead.]
`clamp()` effectively does the same, but is implemented as a function,
which probably makes it faster than a macro or "in-line" code.
Date: 16 Sep 2018 14:26:55
Message: <5b9ea06f$1@news.povray.org>
> Parameters:
> V = Input value.
> Bill
Clamp works, thanks!
Mike
Date: 16 Sep 2018 15:00:25
Message: <5b9ea849$1@news.povray.org>
I am a little confused about the "Solution of Kepler's Equation" on Page
2 of this document. Have I implemented it correctly do you think?
	#local Orrery_Temp_EStar						= 180/pi * Orrery_Temp_Eccentricity;
	#local Orrery_Temp_EccentricAnomaly				= Orrery_Temp_MeanAnomaly +
Orrery_Temp_EStar * sind(Orrery_Temp_MeanAnomaly);
	#local Orrery_Temp_EccentricAnomalyTolerance	= 10e-6;
	#local Orrery_Temp_EccentricAnomalyDelta		= 0;
	#while (abs(Orrery_Temp_EccentricAnomalyDelta) >
Orrery_Temp_EccentricAnomalyTolerance)
		#local Orrery_Temp_MeanAnomalyDelta				= Orrery_Temp_MeanAnomaly -
(Orrery_Temp_EccentricAnomaly - Orrery_Temp_EStar *
sind(Orrery_Temp_EccentricAnomaly));
Orrery_Temp_MeanAnomalyDelta/(1 - Orrery_Temp_Eccentricity *
cosd(Orrery_Temp_EccentricAnomaly));
		#local Orrery_Temp_EccentricAnomaly				= Orrery_Temp_EccentricAnomaly
+ Orrery_Temp_EccentricAnomalyDelta;
Mike
Date: 16 Sep 2018 16:19:39
Message: <5b9ebadb@news.povray.org>
180/pi *
> Orrery_Temp_MeanAnomaly + Orrery_Temp_EStar *
> Orrery_Temp_MeanAnomaly - (Orrery_Temp_EccentricAnomaly -
> Orrery_Temp_EStar * sind(Orrery_Temp_EccentricAnomaly));
> Orrery_Temp_EccentricAnomaly + Orrery_Temp_EccentricAnomalyDelta;
>      #end
> Mike
I did end up finding a bug in that code, but I also discovered that
there's not a visible difference with the code working or not working.
So the major problems I am having lie elsewhere.
Mike
Date: 16 Sep 2018 22:48:47
Message: <5b9f160f$1@news.povray.org>
I found the bug, and will be uploading a corrected version to the Object
Collection shortly.
Mike
