POV-Ray : Newsgroups : povray.advanced-users : Lightsys Server Time
17 May 2024 03:24:42 EDT (-0400)
  Lightsys (Message 11 to 14 of 14)
Subject: Re: Lightsys
Date: 27 Feb 2018 20:38:29
Message: <5a960815@news.povray.org>
Le 18-02-26 à 17:51, Mike Horvath a écrit :
> On 2/24/2018 12:23 PM, Alain wrote:
>> Le 18-02-24 à 11:07, Mike Horvath a écrit :
>>> On 2/23/2018 8:18 AM, Alain wrote:
>>>> The 3 lumen looks a little to bright.
>>>> Can you post the 1 lumen image?
>>>> Also, the sun position is not the same for the two images. It mover
>>>> by around 40°.
>>> Here it is with RGB instead of SRGB, and 1 lumens.
>>> https://i.imgur.com/AcGBbla.jpg
>>> As you can see, it is pretty dim and lifeless.
>>> Mike
>> Slightly dimmer, not prety dim, than the 2 lumens but not lifeless on
>> my monitor. Maybe your monitor is set to dim...
>> Definitively better than the 3 lumens version.
>> Set assumed_gamma 1
>> When using lightsys, always use RGB for the lights. lightsys is made
>> to return values in the rgb colour space, not the srgb one. You may
>> use srgb for the textures.
>> Alain
> My monitor is set to "SRGB". Dunno what it should be set to.
> Mike
Same thing here. sRGB is correct for the monitor.
But, what about the brightness and contrast settings? Normally, contrast
should be set high (100%) and brightness relatively low (<30%).
Brightness is to be adjusted for the ambient lighting level of the room,
but not the contrast.
A low contrast makes your display washed out and generally lifeless.
If you have a saturation setting for the monitor, set it around 50% to
start.
Next, you have the file gamma and display gamma to adjust. File gamma
can be set from 1 to 2.2 or srgb, or something else if you want to.
Display gamma should be the same as your actual gamma setting for the
monitor : SRGB in your case.
Date: 28 Feb 2018 00:02:09
Message: <5a9637d1@news.povray.org>
> start.
I just checked on my phone, and it looks just as bad. So, I don't know
what's wrong with your monitor.
Mike
Date: 28 Feb 2018 00:17:09
Message: <5a963b55$1@news.povray.org>
On 2/25/2018 2:53 AM, Thomas de Groot wrote:
> I often use CIE.inc myself, maybe in a little different way than you do.
> This is an example of how I define my sunlight in a scene:
> #if (Fog)
>    #local Intensity    = 5;
> #else
>    #local Intensity    = 3;
> #end
> //Sun's temperature (Kelvin): 2800=red; 7500=blue white
> #declare SunColor     = Blackbody(6500)*Intensity;
> #declare SunPosition  = <0, 0, -2>*10e4;
> #declare SunDis       = vlength(SunPosition)*2/215;
> #declare Sun_alt      = 60;
> #declare Sun_azm      = -115;
This is much lighter, thanks. But maybe a little too white. I want a bit
more color, but don't have an atmosphere to filter the sun's rays.
Mike
Date: 28 Feb 2018 02:40:20
Message: <5a965ce4$1@news.povray.org>
>> do. This is an example of how I define my sunlight in a scene:
>> #if (Fog)
>> #else
>> #end
Just play with the Intensity value :-)
Intensity=1; would be the normal use. I always adapt according to the
scene I am working on.
