POV-Ray : Newsgroups : povray.advanced-users : Camera scaling and focal_blur? Server Time
28 Apr 2024 23:10:17 EDT (-0400)
  Camera scaling and focal_blur? (Message 19 to 28 of 28)
Subject: Re: Camera scaling and focal_blur?
Date: 12 Feb 2018 16:03:42
Message: <5a82012e$1@news.povray.org>
On 2/12/2018 2:02 PM, Alain wrote:
> Le 18-02-10 à 22:36, Mike Horvath a écrit :
>> I've been reading this
>> https://en.wikipedia.org/wiki/Miniature_faking
>> and have been wondering how to achieve the effect in POV-Ray.
>> Obviously, there is no true scale in POV-Ray, so there's no need to
>> "fake" the effect. But I don't know how to construct the correct camera.
>> Any ideas?
>> Mike
> Use a larger aperture. Something like
> vlength(Camera_Location, Focal_point)/4
> If that's not enough, use a smaller divisor.
Yeah, I got it working. But it doesn't look as good in POV-Ray as it
does in photography. I'll post some test renders soon.
MIke
Date: 13 Feb 2018 10:05:17
Message: <5a82fead$1@news.povray.org>
On 02/11/2018 06:56 PM, Kenneth wrote:
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> ..for a technique using a not yet adopted parser change which allowed
>> image_maps to be used directly in density {} blocks.
> That is *definitely* an interesting and useful idea (as is your current
> workaround.) Any idea if this image_map thing is going to be included in a newer
> v3.8.x alpha or beta?
I've no idea. I've since closed the image_map specific pull request. As
a request it was submitted - as suggested - in place of another adding
image_maps and pigment_maps to density { }. I myself use the latter
branch with both enhancements and maintaining the image_map one was
always extra work for me as I 'git re-based' my branches over time.
In general, I've pruned back on the github pull requests I leave sitting
in the queue though I still publish any branches I think reasonably
solid that others building their own POV-Ray might find useful.
Having a lot of pull requests backed up on github itself becomes a
burden to the build test machines, it slows me down on re-basing and it
generates a lot of email noise especially for the most connected
developers.
Aside: I am sometimes frustrated by the pace at which changes are
adopted - while also understanding it. We must have knowledgeable gate
keepers and planners for the code base and they have only so much time.
Christoph, especially, has often enough saved me from my own ignorance
or improved upon an idea and my actual implementation. We need the pinch
point, the bottleneck for change - and to reasonably pace change given
many have development code efforts running alongside the master branch.
Bill P.
Date: 13 Feb 2018 19:06:34
Message: <5a837d8a$1@news.povray.org>
>>> Any ideas?
>>> Mike
> MIke
As the ratio aperture/focal_length increase, you also need more samples.
Otherwise, the image will get very noisy.
Date: 13 Feb 2018 20:55:01
Message: <web.5a8396e13abb6b9e5cafe28e0@news.povray.org>
Can you
a) mimic and actual camera lens with glass / ior?
b) look through a clear sheet that has a perturbation or normal that gets
progressively stronger toward the edges?
c) look though a partially transparent image map of the scene that somehow gets
rotated a little further the farther out toward the edge you get?
d) otherwise use overlapping image maps to imitate the photographic "circle of
confusion"?
Date: 13 Feb 2018 23:39:34
Message: <5a83bd86$1@news.povray.org>
On 2/13/2018 8:54 PM, Bald Eagle wrote:
> Can you
> confusion"?
I don't know how to do any of these things. It would probably be easier
to just do post-processing in Photoshop.
Mike
Date: 14 Feb 2018 01:27:20
Message: <5a83d6c8$1@news.povray.org>
>> Can you
>> somehow gets
>> "circle of
>> confusion"?
> Mike
I forgot about the fact that my scenes have some tall objects, and the
Photoshop post-processing doesn't work properly in cases like this.
Will a transparent glass really make much of a difference?
Mike
Date: 14 Feb 2018 11:55:43
Message: <5a846a0f@news.povray.org>
Le 18-02-13 à 20:54, Bald Eagle a écrit :
> Can you
Yes. Tou place an object shaped as the desired lense with the desired
ior just in front of the camera. You can also add some dispersion.
This have been actually used.
You can use camera perturbation or use some actual transparent object
with a perturbed normal or some actual displacement.
Then, it's just a question of modulating the pattern.
There are some samples scenes that show how it can be done.
> confusion"?
Date: 14 Feb 2018 17:20:00
Message: <web.5a84b5923abb6b9ea47873e10@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
I just noticed a dumb error I made-- some switched vector coordinates:
> Now, with a more complicated camera position:
> original camera position: <3,13,-9>
> original focal point: <0,0,0>
> With scale 2:
> new camera position: <...? ...> (I'm too lazy to figure it out)
> new focal_point set to: <-13,-3,9>
With scale 2, it should be...
new focal_point set to: <-3,-13,9> // the CORRECT vector
I hope my mistake didn't totally confuse the idea...
Date: 21 Feb 2018 06:28:16
Message: <5a8d57d0$1@news.povray.org>
> Can you
I'm surprised no one has created a library of simulated cameras/lenses
already. POV-Ray has been around for, what, two decades?
Mike
Date: 21 Feb 2018 07:19:10
Message: <5a8d63be@news.povray.org>
>> Can you
Edouard Poor...
Download 'edouard poor - 35mm camera.zip' (51 KB)
