POV-Ray : Newsgroups : povray.advanced-users : Camera scaling and focal_blur? Server Time
15 May 2024 14:52:55 EDT (-0400)
  Camera scaling and focal_blur? (Message 21 to 28 of 28)
Subject: Re: Camera scaling and focal_blur?
Date: 13 Feb 2018 19:06:34
Message: <5a837d8a$1@news.povray.org>
Le 18-02-12 à 16:03, Mike Horvath a écrit :
> On 2/12/2018 2:02 PM, Alain wrote:
>> Le 18-02-10 à 22:36, Mike Horvath a écrit :
>>> I've been reading this
>>> https://en.wikipedia.org/wiki/Miniature_faking
>>> and have been wondering how to achieve the effect in POV-Ray.
>>> Obviously, there is no true scale in POV-Ray, so there's no need to
>>> "fake" the effect. But I don't know how to construct the correct camera.
>>> Any ideas?
>>> Mike
>> Use a larger aperture. Something like
>> vlength(Camera_Location, Focal_point)/4
>> If that's not enough, use a smaller divisor.
> Yeah, I got it working. But it doesn't look as good in POV-Ray as it
> does in photography. I'll post some test renders soon.
> MIke
As the ratio aperture/focal_length increase, you also need more samples.
Otherwise, the image will get very noisy.
Date: 13 Feb 2018 20:55:01
Message: <web.5a8396e13abb6b9e5cafe28e0@news.povray.org>
Can you
a) mimic and actual camera lens with glass / ior?
b) look through a clear sheet that has a perturbation or normal that gets
progressively stronger toward the edges?
c) look though a partially transparent image map of the scene that somehow gets
rotated a little further the farther out toward the edge you get?
d) otherwise use overlapping image maps to imitate the photographic "circle of
confusion"?
Date: 13 Feb 2018 23:39:34
Message: <5a83bd86$1@news.povray.org>
On 2/13/2018 8:54 PM, Bald Eagle wrote:
> Can you
> confusion"?
I don't know how to do any of these things. It would probably be easier
to just do post-processing in Photoshop.
Mike
Date: 14 Feb 2018 01:27:20
Message: <5a83d6c8$1@news.povray.org>
>> Can you
>> somehow gets
>> "circle of
>> confusion"?
> Mike
I forgot about the fact that my scenes have some tall objects, and the
Photoshop post-processing doesn't work properly in cases like this.
Will a transparent glass really make much of a difference?
Mike
Date: 14 Feb 2018 11:55:43
Message: <5a846a0f@news.povray.org>
Le 18-02-13 à 20:54, Bald Eagle a écrit :
> Can you
Yes. Tou place an object shaped as the desired lense with the desired
ior just in front of the camera. You can also add some dispersion.
This have been actually used.
You can use camera perturbation or use some actual transparent object
with a perturbed normal or some actual displacement.
Then, it's just a question of modulating the pattern.
There are some samples scenes that show how it can be done.
> confusion"?
Date: 14 Feb 2018 17:20:00
Message: <web.5a84b5923abb6b9ea47873e10@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
I just noticed a dumb error I made-- some switched vector coordinates:
> Now, with a more complicated camera position:
> original camera position: <3,13,-9>
> original focal point: <0,0,0>
> With scale 2:
> new camera position: <...? ...> (I'm too lazy to figure it out)
> new focal_point set to: <-13,-3,9>
With scale 2, it should be...
new focal_point set to: <-3,-13,9> // the CORRECT vector
I hope my mistake didn't totally confuse the idea...
Date: 21 Feb 2018 06:28:16
Message: <5a8d57d0$1@news.povray.org>
> Can you
I'm surprised no one has created a library of simulated cameras/lenses
already. POV-Ray has been around for, what, two decades?
Mike
Date: 21 Feb 2018 07:19:10
Message: <5a8d63be@news.povray.org>
>> Can you
Edouard Poor...
Download 'edouard poor - 35mm camera.zip' (51 KB)
