POV-Ray : Newsgroups : povray.advanced-users : Plotting CMYK coordinates in a 3D space Server Time
6 Jan 2025 15:55:18 EST (-0500)
  Plotting CMYK coordinates in a 3D space (Message 1 to 4 of 4)
Subject: Plotting CMYK coordinates in a 3D space
Date: 30 Mar 2017 15:42:23
Message: <58dd5f9f$1@news.povray.org>
I am using the following code to generate XYZ coordinates for the outer
surface of the SRGB gamut:
#macro cie_calc_gamut_xyz_srgb()
	// should handle black in the xyY space separately, but am unsure how
	#for (i, 0, cie_sample_count_srgb)
		#for (j, 0, cie_sample_count_srgb)
			// side 0 & 3
			#local cooRGB = <i/cie_sample_count_srgb,j/cie_sample_count_srgb,0>;
			#local cooXYZ = cie_convRGB2XYZ(cooRGB);
			#declare cie_point_array_srgb[0][i][j] = cooXYZ;
			#local cooRGB = <i/cie_sample_count_srgb,j/cie_sample_count_srgb,1>;
			#declare cie_point_array_srgb[3][i][j] = cooXYZ;
			// side 1 & 4
			#local cooRGB = <i/cie_sample_count_srgb,0,j/cie_sample_count_srgb>;
			#declare cie_point_array_srgb[1][i][j] = cooXYZ;
			#local cooRGB = <i/cie_sample_count_srgb,1,j/cie_sample_count_srgb>;
			#declare cie_point_array_srgb[4][i][j] = cooXYZ;
			// side 2 & 5
			#local cooRGB = <0,i/cie_sample_count_srgb,j/cie_sample_count_srgb>;
			#declare cie_point_array_srgb[2][i][j] = cooXYZ;
			#local cooRGB = <1,i/cie_sample_count_srgb,j/cie_sample_count_srgb>;
			#declare cie_point_array_srgb[5][i][j] = cooXYZ;
The sRGB space is roughly a misshapen cube, with 8 corners for red,
green, blue, cyan, magenta, yellow, white and black. And each face of
this cube is roughly two-dimensional.
But CMYK has 4 values instead of 3, and it's really throwing me for a
loop. How do I plot points along its outer surface?
Mike
Subject: Re: Plotting CMYK coordinates in a 3D space
Date: 30 Mar 2017 15:51:50
Message: <58dd61d6$1@news.povray.org>
I forgot to also say that I am treating each of the 6 faces of the cube
individually. Imagine an 2D grid. I am plotting each x and y coordinate
to generate a single 2D face, and am doing this 6 times to generate all
6 cube faces.
Not sure how to do this with CMYK. I don't think I want to generate a
four-dimensional object. Or do I?
Mike
Date: 31 Mar 2017 03:44:04
Message: <58de08c4$1@news.povray.org>
> 6 cube faces.
> Mike
It just occured to me that creating a four-dimensional isosurface might
be tricky too.
Mike
Date: 31 Mar 2017 23:57:18
Message: <58df251e$1@news.povray.org>
> Mike
Converting to/from CMYK involves additional steps due to color profiles
and such. I think I will skip it.
Mike
