POV-Ray : Newsgroups : povray.advanced-users : Color matching functions Server Time
25 Apr 2024 19:57:25 EDT (-0400)
  Color matching functions (Message 1 to 4 of 4)
Subject: Color matching functions
Date: 21 Mar 2017 23:12:30
Message: <58d1eb9e$1@news.povray.org>
The CMFs I am currently using are in 5nm steps from 360nm to 830nm,
which is 95 steps total.
Are there more detailed samples? Are there more detailed samples for D65
illumination too? The CMFs and illuminations should have the same number
of steps in the same range, since my script is set up to iterate through
both sets of samples at the same time. Not sure what to do if the sample
tables aren't the same sizes.
Thanks.
Mike
Subject: Re: Color matching functions
Date: 22 Mar 2017 04:27:05
Message: <58d23559$1@news.povray.org>
> Thanks.
> Mike
Wikipedia says you can just interpolate between the 5nm points to
generate narrower ones. Lightsys uses a spline apparently.
Mike
Date: 22 Mar 2017 12:35:43
Message: <58d2a7df$1@news.povray.org>
Am 22.03.2017 um 04:12 schrieb Mike Horvath:
http://cvrl.ioo.ucl.ac.uk/ provides some spectral data tables in steps
as small as 0.1nm.
I guess a lot of that is interpolated though. To my knowledge, the
original data was measured in steps of 5nm.
Date: 22 Mar 2017 18:35:10
Message: <58d2fc1e@news.povray.org>
>> Thanks.
>> Mike
> Mike
Yes, Lightsys use splines everywhere.
Most of the time, a linear spline is enough, but you may want to use
some other kind of spline.
