POV-Ray : Newsgroups : povray.advanced-users : CIE xyY color space Server Time
29 Apr 2024 08:45:37 EDT (-0400)
  CIE xyY color space (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: CIE xyY color space
Date: 16 Mar 2017 09:40:11
Message: <58ca95bb@news.povray.org>
Am 16.03.2017 um 12:57 schrieb Bald Eagle:
> As for my original intent, my "analysis" is an effort to rapidly get a more
> pleasing result from sampled colors for use in color maps when trying to
> procedurally texture things.  You may recall my lamentations about trying to
> replicate the beautiful honey-yellow coloration of a wood floor, since my color
> maps only produced pale, washed-out results that weren't anywhere near what I
> wanted.
To be honest, no, I don't remember those lamentations.
Sounds pretty much like a gamma issue to me.
Date: 16 Mar 2017 10:10:01
Message: <web.58ca9bfe55b89017c437ac910@news.povray.org>
It was Oct 2014, so not surprising.
http://news.povray.org/web.5435881bcbb3d8155e7df57c0%40news.povray.org
Date: 16 Mar 2017 10:45:18
Message: <58caa4fe$1@news.povray.org>
Am 16.03.2017 um 15:06 schrieb Bald Eagle:
`[0.4 rgb <184/255, 115/255, 48/255> * Tone]`
Yeah. Any expression starting with "rgb" and containing integer numbers
divided by 255 screams "gamma issue!" at the top of its lungs.
Integer numbers divided by 255 are a sign that the colour were
originally encoded as a byte triplet, most likely raw image values, e.g.
as picked from an image using external tool.
Raw image values typically use non-linear colour values, the best bet
being sRGB.
To specify sRGB colours, you need to use the `srgb` keyword instead of
`rgb`, otherwise you get the colour's gamma wrong.
Unless your scene uses `assumed_gamma srgb` (or an approximate value,
such as `assumed_gamma 2.2`), in which case your entire image suffers
from gamma issues.
(It should be noted that `srgb <184/255, 115/255, 48/255> * Tone`
doesn't give you exactly what you are asking for. Theoretically it
should be `(srgb <184/255, 115/255, 48/255>) * Tone`, but that's
currently not allowed by the parser.)
Date: 16 Mar 2017 11:47:03
Message: <58cab377$1@news.povray.org>
On 3/12/2017 12:04 AM, Mike Horvath wrote:
> On 3/10/2017 1:19 PM, Mike Horvath wrote:
>> What value ranges are appropriate for this color space? I'm guessing Y
>> (uppercase) ranges from 0 to 100. But what about x and y? Thanks.
>> Mike
> I tried rendering something in this color space. I've tried all the
> methods suggested so far, but am still getting "disappearing" areas of
> the shape. See the "Holes in isosurface 3" thread in p.t.s-f.
> Mike
I was able to get it to work. Render times were much longer than
previous scenes in this series, however. At 2048x2048 pixels, it took 6
hours to get to 80%, and an extra 24 hours to get from 80% to 100%.
Mike
Date: 16 Mar 2017 13:00:01
Message: <web.58cac3b955b89017c437ac910@news.povray.org>
Excellent information, as always.
Al ways, always, always learning something new and useful here.   :)
So something along the lines of this would be necessary:
(untested, needs handling of optional transmit and filter values)
#macro RGB2SRGB (C_linear)
 // https://en.wikipedia.org/wiki/SRGB
 // C_linear is a standard rgb color vector
 #local RGB = array[3] {C_linear.red, C_linear.green, C_linear.blue};
 #local SRGB = array[3];
 #local _a = 0.055;
 #local _Threshold = 0.0031308;
 #local _Gamma = 2.4;
 #for (Component, 0, 2)
  #if (RGB[Component] <= _Threshold)
   #local SRGB[Component] = 12.92 * RGB[Component];
  #else
   #local SRGB[Component] = ((1 + _a) * pow (RGB[Component], 1/_Gamma)) - _a;
  #end // end if
 #end // end for Component
 #local C_srgb = <SRGB[0], SRGB[1], SRGB[2]>
 C_srgb
#end // end macro RGB2SRGB
Date: 16 Mar 2017 14:08:31
Message: <58cad49f$1@news.povray.org>
>  #local _a = 0.055;
>   #else
>   #end // end if
>  C_srgb
Are you trying to come up with a way to interpolate between different
sRGB values? I think clipla said sRGB space is nonlinear.
Mike
Date: 16 Mar 2017 14:55:00
Message: <web.58cade7855b89017c437ac910@news.povray.org>
> sRGB values?
Nope.  Convert from RGB to srbg
Yup.  That's why there's the exponential term.
Date: 16 Mar 2017 20:08:55
Message: <58cb2917$1@news.povray.org>
Am 16.03.2017 um 17:56 schrieb Bald Eagle:
No, what would be necessary is just the opposite: A mechanism to convert
from sRGB to linear. Because picked colours tend to be in sRGB, and what
POV-Ray needs deep down in its heart is linear.
Which is precisely what the `srgb` keyword was designed to do (presuming
you're using `assumed_gamma 1.0` like you should).
The only drawback is that you can't put `srgb` in brackets to multiply
that expression (which would be a linear colour) with a `Tone` factor.
And if you omit the bracket you get a multiplication in sRGB space
(effectively `srgb (<...>*Tone)`), which isn't exactly what you need.
Date: 17 Mar 2017 15:20:00
Message: <web.58cc35cc55b89017c437ac910@news.povray.org>
Have you considered doing an overlay or an animated fade-in/fade-out of all the
color spaces you've rendered?
Date: 17 Mar 2017 16:38:24
Message: <58cc4940$1@news.povray.org>
I was thinking of showing the sRGB gamut and visible gamut next to each
other, or overlaid. Need to finish working out how to do the visible
gamut, first.
Mike
