POV-Ray : Newsgroups : povray.advanced-users : Spherical isosurface Server Time
14 May 2024 00:08:25 EDT (-0400)
  Spherical isosurface (Message 11 to 17 of 17)
Subject: Re: Spherical isosurface
Date: 29 Nov 2016 17:04:33
Message: <583dfb71$1@news.povray.org>
On 11/29/2016 3:26 PM, clipka wrote:
> Luminance gets a bit more complicated: You have to use an atan-based
> formula to get an angle, but you must plug in the y coordinate and the
> distance between the y axis; the latter is equal to sqrt(x*x+z*z), so
> this gives you:
>     #declare fL = function(x,y,z) { atan2(sqrt(x*x+z*z),y)*CONST }
> Choose CONST values as needed; atan2()*CONST may happen to be replacable
> by atan2d() again.
Wikipedia says it should be more like
	#declare fL = function(x,y,z) { atan2(sqrt(x*x+y*y+z*z),y)*CONST }
Do you agree?
Mike
Date: 29 Nov 2016 17:07:14
Message: <583dfc12$1@news.povray.org>
>> this gives you:
>> by atan2d() again.
> Do you agree?
> Mike
Wait! I scanned your response too quickly. Wikipedia gives this:
	acos(y/r)
which is totally different from what you suggest. Are they equivalent?
Mike
Date: 29 Nov 2016 17:12:52
Message: <583dfd64$1@news.povray.org>
> this gives you:
> by atan2d() again.
Also, don't I need to divide by 180 first before multiplying by the
constant?
atan2d(sqrt(x*x+z*z),y)/180*100
Mike
Date: 29 Nov 2016 19:01:44
Message: <583e16e8$1@news.povray.org>
Am 29.11.2016 um 23:07 schrieb Mike Horvath:
>>> this gives you:
>>> by atan2d() again.
>> Do you agree?
>> Mike
>     acos(y/r)
I think so. Wikipedia is right, and I'm confident my formula is also
correct. I haven't verified the equivalence algebraically though.
Date: 29 Nov 2016 19:07:26
Message: <583e183e$1@news.povray.org>
Am 29.11.2016 um 23:12 schrieb Mike Horvath:
>> this gives you:
>> by atan2d() again.
> constant?
Well, that's equivalent to
    atan2(...)/pi*100
so it's just a matter of choosing a fitting CONST for your purposes ;)
But yes, the way you're doing it is probably right for your application.
I later noticed that you may need to add another constant though,
depending on the nominal value range.
Date: 1 Dec 2016 18:40:40
Message: <5840b4f8$1@news.povray.org>
Le 16-11-28 à 18:42, Mike Horvath a écrit :
> Clipka gave me these formulas to generate a cylindrical isosurface.
> #declare fL = function(x,y,z) {y*100}
> #declare fC = function(x,y,z) {sqrt(x*x+z*z)*128}
> #declare fH = function(x,y,z) {atan2d(x,z)}
> What would be a formula for a sphere? L should be latitude, H longitude,
> and C radius.
> Thanks.
When I want a isosurface sphere, I use the following:
#include "functions.inc"
Then, I use the f_sphere(x,y,z,radius) function that use an internal
function. Faster and simple.
If you want the function to use in an isosurface, it's
sqrt(pow(x,2)+pow(y,2)+pow(z,2))-Radius to be used with a threshold of zero.
Also, you can use sqrt(pow(x,2)+pow(y,2)+pow(z,2)) and use the threshold
to controll the radius.
Using 3 functions is if you want to make a parametric sphere. It's not
the same thing.
Date: 1 Dec 2016 20:16:12
Message: <5840cb5c$1@news.povray.org>
>> and C radius.
>> Thanks.
> zero.
> the same thing.
> Alain
I don't want a sphere. I want an irregular shape in a spherical
coordinate system.
Mike
