POV-Ray : Newsgroups : povray.advanced-users : CIE 1931 color space chromaticity diagram Server Time
14 Mar 2026 11:09:01 EDT (-0400)
  CIE 1931 color space chromaticity diagram (Message 1 to 9 of 9)
Subject: CIE 1931 color space chromaticity diagram
Date: 26 Nov 2016 11:13:47
Message: <5839b4bb$1@news.povray.org>
How do you plot this horseshoe shape? Is the diagram plotted in CIE XYZ
or CIE xyY color space? How do you tell if a point is inside or outside
this curve?
Mike
Subject: Re: CIE 1931 color space chromaticity diagram
Date: 26 Nov 2016 11:30:45
Message: <5839b8b5$1@news.povray.org>
> this curve?
> Mike
I found this code.
http://www.mathworks.com/matlabcentral/fileexchange/40640-computational-colour-science-using-matlab-2e/content/cieplot.m?requestedDomain=www.mathworks.com
However, there is only x and y, so it ignores the third dimension.
Mike
Date: 26 Nov 2016 11:43:40
Message: <5839bbbc$1@news.povray.org>
Am 26.11.2016 um 17:13 schrieb Mike Horvath:
It can be considered a plot of CIE xyY at some arbitrary unity Y.
Alternatively, it can be considered a plot of the slice X+Y+Z=1 of the
CIE XYZ colour space projected onto the XY plane.
> this curve?
By comparing against empirically established tables. There's no way
around that.
Date: 26 Nov 2016 12:04:45
Message: <5839c0ad$1@news.povray.org>
Am 26.11.2016 um 17:30 schrieb Mike Horvath:
>> this curve?
>> Mike
> I found this code.
The third dimension is Y, luminance, aka brightness.
It has a lower bound of zero, but no natural upper bound, as light can
be arbitrarily bright.
Date: 26 Nov 2016 16:31:39
Message: <5839ff3b$1@news.povray.org>
>>> this curve?
>>> Mike
>> I found this code.
Illuminant D65 seems to be quite popular. Might that not serve as an
upper bound?
Mike
Date: 26 Nov 2016 17:41:56
Message: <583a0fb4@news.povray.org>
Am 26.11.2016 um 22:31 schrieb Mike Horvath:
> upper bound?
/Any/ illuminant can serve as an upper limit -- but the question is,
does it make sense in the context? Popularity is not a criterium here.
Unless you have a specific reason for chosing any particular whitepoint,
the only one that stands out is whitepoint E (equal energy).
Another candidate for an upper limit would be Y=1.
Date: 26 Nov 2016 20:10:10
Message: <583a3272$1@news.povray.org>
>> upper bound?
Well, I *think* the ColorMine formulas use D65 by default. So I will
just stick with that.
Mike
Date: 28 Nov 2016 07:02:42
Message: <583c1ce2$1@news.povray.org>
Am 11/26/2016 um 17:13 schrieb Mike Horvath:
> this curve?
> Mike
My include file CIE.inc* contains all the necessary tables for plotting
the horseshoe diagram.
*part of my spectral render system
http://www.lilysoft.org/CGI/SR/Spectral%20Render.htm
and
Lightsys IV
http://www.ignorancia.org/en/index.php?page=Lightsys
-Ive
Date: 4 Dec 2016 11:05:02
Message: <58443eae$1@news.povray.org>
>> this curve?
>> Mike
> and
> Lightsys IV
> -Ive
I looked at CIE.inc briefly, and it has a lot of macros but no real
functions. I'm not sure I can adapt the code.
Mike
