POV-Ray : Newsgroups : povray.advanced-users : Isosurface threshold 0..1 Server Time
29 Mar 2024 11:37:04 EDT (-0400)
  Isosurface threshold 0..1 (Message 11 to 12 of 12)
Subject: Re: Isosurface threshold 0..1
Date: 24 Nov 2016 14:07:30
Message: <58373a72$1@news.povray.org>
On 11/23/2016 8:51 PM, clipka wrote:
> Am 24.11.2016 um 01:27 schrieb Mike Horvath:
>> On 11/23/2016 7:22 PM, Christian Froeschlin wrote:
>>> No threshold will give the desired result using the color
>>> conversion function directly, as clipka explained you need
>>> a define a "distance" function for this purpose.
>>> Alternatively you could try to render the clipped function
>>> (set to 0 outside the gamut) as strongly scattering media but
>>> it may be fiddly and you don't get the look of a "surface"
>>> regarding finish and lighting etc.
>> What is a "distance" function?
>> The "convertLCH2RGBb2(y*100,sqrt(x*x+z*z)*100,atan2d(x,z))" bit is what
>> clipka showed me.
> You may need to deconstruct the problem into easy-to-handle building
> blocks, and tackle each of them separately.
> One building block you need is a function that maps a single RGB colour
> component to a distance-ish scalar telling you how "far away" the colour
> component is from the valid range (this time, just for giggles, I'm
> contructing the function in such a way that <0 is inside, >0 is outside):
>     #declare fD = function(C) { abs(C-0.5)-0.5 }
> Another building block you need is a function that combines three such
> distance-ish scalars, such that you get a positive value if one or more
> parameters is positive, or a negative value if all are negative, in a
> manner that avoid steps:
>     #declare fDist = function(Dr,Dg,Db) { max(Dr,Dg,Db) }
> That's kind of all you need to know about the "distance" functions;
> however, those functions alone don't get you anywhere.
> Another necessary building block is a set of functions that map Lch to RGB:
>     #declare fR = function(L,c,h) { ... }
>     #declare fG = function(L,c,h) { ... }
>     #declare fB = function(L,c,h) { ... }
> And the final building block is a set of functions that map 3D cartesian
> space to Lch:
>     #declare fL = function(x,y,z) { y*100 }
>     #declare fc = function(x,y,z) { sqrt(x*x+z*z)*100 }
>     #declare fh = function(x,y,z) { atan2d(x,z) }
> Once you have all these building blocks, all that's left is to plug them
> all together.
> The final result to be compared to the threshold by the isosurface is
> the result of the `fDist` function, so that's where you start:
>     isosurface {
>       threshold 0
>       function { fDist (Dr,Dg,Db) }
> The isosurface doesn't know what `Dr`, `Dg` and `Db` are, but we know
> they are supposed to be results of the `fD` function, using the three
> colour channels as input:
>     isosurface {
>       threshold 0
>       function { fDist (
>         fD (R),
>         fD (G),
>         fD (B)
> Again the isosurface doesn't know `R`, `G` and `B`:
>     isosurface {
>       threshold 0
>       function { fDist (
>         fD ( fR (L,c,h) ),
>         fD ( fG (L,c,h) ),
>         fD ( fB (L,c,h) )
> Still not done yet, as the isosurface doesn't know `L`, `c` and `h` either:
>     isosurface {
>       threshold 0
>       function { fDist (
>         fD ( fR (fL(x,y,z),fc(x,y,z),fh(x,y,z)) ),
>         fD ( fG (fL(x,y,z),fc(x,y,z),fh(x,y,z)) ),
>         fD ( fB (fL(x,y,z),fc(x,y,z),fh(x,y,z)) )
> Now we have only `x`, `y` and `z` left as parameters, which is what the
> isosurface can handle.
> For bonus points, you could eliminate the multiple invocation of
> `fL(x,y,z)`, `fc(x,y,z)` and `fh(x,y,z)`. To this end, you need to
> provide a function that does not compute these values itself, but rather
> takes them as parameters:
>     #declare fFinal = function(L,c,h) { fDist (
>       fD ( fR (L,c,h) ),
>       fD ( fG (L,c,h) ),
>       fD ( fB (L,c,h) )
>     isosurface {
>       threshold 0
>       function { fFinal (fL(x,y,z),fc(x,y,z),fh(x,y,z)) }
> And of course you'll want to use different names; I chose the above for
> brevity.
Next issue: What is the best way to create an accurate pigment to paint
the isosurface?
I was thinking of repurposing the following:
// HSL Cylinder
#declare CSolid_HSLCylinder_Hue = pigment
	function {-f_th(x,y,z)/pi/2}
	color_map
		// need to replace these with calls to CHSL2RGB() or CH2RGB(), then
increase the number of steps
		[0/6 srgb <1,0,0,>]
		[1/6 srgb <1,1,0,>]
		[2/6 srgb <0,1,0,>]
		[3/6 srgb <0,1,1,>]
		[4/6 srgb <0,0,1,>]
		[5/6 srgb <1,0,1,>]
		[6/6 srgb <1,0,0,>]
#declare CSolid_HSLCylinder_Saturation = pigment
	cylindrical
	pigment_map
		[0 CSolid_HSLCylinder_Hue]
		[1 color srgb 1/2]
	scale	(1 + CSolid_Offset)
#declare CSolid_HSLCylinder_Lightness = pigment
	gradient y
	pigment_map
		[0/2 color srgb 0]
		[1/2 CSolid_HSLCylinder_Saturation]
		[2/2 color srgb 1]
	translate	-y * CSolid_Offset/2
#declare CSolid_HSLCylinder_Pigment = pigment {CSolid_HSLCylinder_Lightness}
Except, in this case using LCH conversion formula to create the gradients:
	[0/6 srgb <convertLCH2RGBb1(50, 50, 0),convertLCH2RGBb2(50, 50,
0),convertLCH2RGBb3(50, 50, 0)>]
	[1/6 srgb <convertLCH2RGBb1(50, 50, 60),convertLCH2RGBb2(50, 50,
60),convertLCH2RGBb3(50, 50, 60)>]
	[2/6 srgb <convertLCH2RGBb1(50, 50, 120),convertLCH2RGBb2(50, 50,
120),convertLCH2RGBb3(50, 50, 120)>]
	[3/6 srgb <convertLCH2RGBb1(50, 50, 180),convertLCH2RGBb2(50, 50,
180),convertLCH2RGBb3(50, 50, 180)>]
	[4/6 srgb <convertLCH2RGBb1(50, 50, 240),convertLCH2RGBb2(50, 50,
240),convertLCH2RGBb3(50, 50, 240)>]
	[5/6 srgb <convertLCH2RGBb1(50, 50, 300),convertLCH2RGBb2(50, 50,
300),convertLCH2RGBb3(50, 50, 300)>]
	[6/6 srgb <convertLCH2RGBb1(50, 50, 360),convertLCH2RGBb2(50, 50,
360),convertLCH2RGBb3(50, 50, 360)>]
Is this maybe a bad idea?
Mike
Date: 24 Nov 2016 14:10:20
Message: <58373b1c$1@news.povray.org>
>>> clipka showed me.
>> RGB:
>> space to Lch:
>> all together.
>>     isosurface {
>>       threshold 0
>>     isosurface {
>>       threshold 0
>>       function { fDist (
>>         fD (R),
>>         fD (G),
>>         fD (B)
>>     isosurface {
>>       threshold 0
>>       function { fDist (
>>         fD ( fR (L,c,h) ),
>>         fD ( fG (L,c,h) ),
>>         fD ( fB (L,c,h) )
>> either:
>>     isosurface {
>>       threshold 0
>>       function { fDist (
>>       fD ( fR (L,c,h) ),
>>       fD ( fG (L,c,h) ),
>>       fD ( fB (L,c,h) )
>>     isosurface {
>>       threshold 0
>> brevity.
> the isosurface?
> // HSL Cylinder
>     color_map
> then increase the number of steps
>         [0/6 srgb <1,0,0,>]
>         [1/6 srgb <1,1,0,>]
>         [2/6 srgb <0,1,0,>]
>         [3/6 srgb <0,1,1,>]
>         [4/6 srgb <0,0,1,>]
>         [5/6 srgb <1,0,1,>]
>         [6/6 srgb <1,0,0,>]
>     cylindrical
>     pigment_map
>         [1 color srgb 1/2]
>     gradient y
>     pigment_map
>         [0/2 color srgb 0]
>         [2/2 color srgb 1]
> Mike
Disregard. I will ask this in the proper thread.
Mike
