POV-Ray : Newsgroups : povray.advanced-users : function select logic Server Time
16 May 2026 19:05:48 EDT (-0400)
  function select logic (Message 1 to 10 of 17)
Subject: function select logic
Date: 23 Nov 2016 01:59:17
Message: <58353e45$1@news.povray.org>
I have the following three functions:
#declare correctRGB_R = function(R,G,B) {min(max(R,0),1)}
#declare correctRGB_G = function(R,G,B) {min(max(G,0),1)}
#declare correctRGB_B = function(R,G,B) {min(max(B,0),1)}
They each process input and output one component of an R,G,B color vector.
However, instead of the above, I want the entire vector discarded if
*any* of R, G or B is less than zero or greater than one.
I'm not sure how to form the select statement. What is the best way to
do this?
Mike
Subject: Re: function select logic
Date: 23 Nov 2016 07:55:00
Message: <web.583590e8a279be30c437ac910@news.povray.org>
> do this?
> Mike
Wrap all three #declares in a conditional block?
#if (R>1 | R<0 | G>1 | G<0 | B>1 | B<0)
     // do nothing, or whatever else you want
#else
or something along those lines....
Date: 23 Nov 2016 09:30:26
Message: <5835a802$1@news.povray.org>
>> do this?
>> Mike
What do you mean by discarded? A function must always return a value,
there is no "discarded" option. Where/how are you going to use these
three functions and what do you want the final result to be if the input
RGB is out of range? You could return a special value like -1 to
indicate a "discarded" vector - but it depends what you're going to do
next with the result.
> #else
> #end
That's just going to decide whether or not to declare the functions in
the scene, on some unrelated RGB variables (RGB in the function
definitions are just parameters). It won't affect the behaviour of the
function when it is actually used later on (apart from getting an error
that it is undefined).
Date: 23 Nov 2016 10:05:01
Message: <web.5835afe1a279be30c437ac910@news.povray.org>
That was my concern as well.
I thought of a similar -1 or other "flag" value - and then he could set transmit
to 1 so it's essentially invisible.
Well that was the "or..." part of the "do nothing" conditional result.
#declare RGB = color rgbt <1, 1, 1, 1>;
would be a default "hide / 'discard' this out of range result"
Date: 23 Nov 2016 10:40:14
Message: <5835b85e$1@news.povray.org>
I think you misunderstand my point. Any #if, #declare etc will only get
evaluated once when the scene is parsed. You'll end up with either your
function declared or not declared. When you come to use that function in
a pigment or isosurface or whatever your #if #declare statements won't
be executed again. Any logic needs to go inside the function declaration
using the select function, not #if.
Using the transmit channel is a good idea though. You could define
another function for calculating the transmit value, that just returns 1
if any of RGB parameters are out of range, or zero otherwise. This needs
to be a select statement inside a function though, not using #if.
Date: 23 Nov 2016 11:00:01
Message: <web.5835bcf1a279be30c437ac910@news.povray.org>
True.
Though I was looking at "equations" not any declared functions.
I think that Mike is going to have a devil of a time trying to get that to go
with an isosurface.  That needs to be an implicit surface, no?
I'm leaning towards a parametric using splines defined by points resulting from
his stack-of-blocks code.
Maybe someone more clever, and with more round-tuits has a more elegant
solution....
Date: 23 Nov 2016 11:09:42
Message: <5835bf46$1@news.povray.org>
> True.
If this is the case then it's very easy, no need to use any functions or
select at all ... sorry, blatant copy&paste of your example :-)
#else
      // we know here that RGB are all within the 0...1 range, so no need
      // to clamp with min/max
      object{ blah blah pigment{ color rgb <R,G,B>} }
But I got the impression from Mike's post that he needed a function to
do this for use later (maybe in a pigment?).
Date: 23 Nov 2016 12:20:01
Message: <web.5835cfbaa279be30c437ac910@news.povray.org>
Does this work?
#version 3.7;
global_settings {assumed_gamma 1.0}
#declare LimitRange = function (Number) {
 select (Number,      // Input
 666,        // special flag value for values less than zero
 select (1-Number, 666, Number)  // second select operation
 )        // 1 - 0 = 1
}         // 1 - 1 = 0
         // 1 - 1.1 = - 0.1
         // so using (1 - Number) then filters out numbers greater than 1
#for (Number, -1, 2, 0.5)
 #declare Result = LimitRange (Number);
 #debug concat( "Number = ", str(Number, 3, 1),  "     Result = ", str(Result,
3, 1), "\n")
Date: 23 Nov 2016 12:20:15
Message: <5835cfcf$1@news.povray.org>
It's for an isosurface, actually, not a color. It just so happens I'm
modeling a color solid. So color = shape. Sorry.
When any of R, G or B are outside the range 0..1, then I do not want it
to be part of the shape. I think a select statement can do this.
Mike
Date: 23 Nov 2016 15:50:24
Message: <58360110$1@news.povray.org>
>  )        // 1 - 0 = 1
> }         // 1 - 1 = 0
>          // 1 - 1.1 = - 0.1
> 3, 1), "\n")
> #end
Can this be used to generate an isosurface? Will the 666 break an
isosurface?
Mike
