POV-Ray : Newsgroups : povray.advanced-users : Stochastics expertise needed Server Time
7 Jan 2025 22:13:39 EST (-0500)
  Stochastics expertise needed (Message 1 to 10 of 26)
Subject: Stochastics expertise needed
Date: 25 Aug 2016 20:15:43
Message: <57bf8a2f$1@news.povray.org>
Folks, I could need a bit of help with a maths problem.
I need an algorithm to generate random points on the surface of a
sphere, conforming to the following criteria:
- The distribution must be radially symmetric around the Y axis.
- The sample density should be roughly uniform, except for a pronounced
peak centered at +Y (but not -Y!)
- For each random point generated, the algorithm also needs to compute
the theoretical sample density at that location.
- The algorithm must be reasonably fast.
Ideally, the algorithm should also have the following properties:
- The density should fall off smoothly from the peak.
- The algorithm should have a parameter to govern the "tightness" of the
peak.
- The sample density away from the peak should approach (but not reach!)
zero.
Subject: Re: Stochastics expertise needed
Date: 26 Aug 2016 04:30:00
Message: <web.57bffd228629941bdadd19850@news.povray.org>
> peak.
> zero.
I suppose no. 16 on http://mathworld.wolfram.com/SpherePointPicking.html hints
at the solution: You "just" need a space defined by a vector that meets the
above criteria. The "distortion" of the space at the selected point will then
allow computation of a scalar that should have some relation to the sample
density. Basically, with the shape of the unit hull you can also shape the
sample density by projecting it back on a unit sphere.
However, I am not sure if the "incorrect" example on that page won't
already solve most of your problem.
Date: 26 Aug 2016 05:36:31
Message: <57c00d9f@news.povray.org>
Am 26.08.2016 um 10:28 schrieb Thorsten Froehlich:
"_hints_ at the solution"... "_some_ relation to the sample density"...
(emphasis added)... I think I see a pattern there ;)
Not exactly:
- It has samples bunching up at both poles, not just +Y.
- The tightness of the bunching-up cannot be tweaked.
- The off-peak density does not approach zero.
Date: 26 Aug 2016 11:45:00
Message: <web.57c063998629941bb488d9aa0@news.povray.org>
I'm busy at the moment, but:
define a sphere with radius 0.5
pow(x,2) + pow(y,2) = 0.5
so pow(y,2) = 0.5 - pow(x,2)
and y = sqrt ( 0.5 - pow(x,2))
translate y*0.5
y = sqrt ( 0.5 - pow(x,2)) +0.5
make your function equal to the sin of that times pi/2 so that the function
smoothly increases from 0 to 1
add the smallest number POV will work with to that (1E-whatever)
Multiply that by a line equation, the slop of which is the tightness
I will give this some more thought
Date: 26 Aug 2016 12:50:01
Message: <web.57c072418629941bb488d9aa0@news.povray.org>
Try this as a starting point
// spherical pattern
// Bald Eagle 2016
#version 3.7;
global_settings {assumed_gamma 1.0}
#include "textures.inc"
#include "rand.inc"
 location <0, 0.5, -2>
 look_at  <0, 0.5, 0>
light_source {<20, 50, -100> White shadowless}
#declare R = 0.5;
#declare Tiny = 0.000001;
#declare Stream = seed (123);
#for (Point, 1, 5000)
    #declare Variable = (VRand_On_Sphere(Stream)*0.5 + <0, 0.5, 0>);
    #debug concat( "Variable = ", vstr(3, Variable, ", ", 3, 3), " \n")
    #declare Color = <abs(pow (Variable.y, 1))+Tiny, 0, 0>;
    #debug concat( "Color = ", vstr(3, Color, ", ", 3, 3), " \n")
    sphere {Variable, 0.01 pigment {rgb Color}}
Date: 26 Aug 2016 13:15:01
Message: <web.57c078cf8629941b69e826dc0@news.povray.org>
> peak.
> zero.
I see a certain contradiction because a uniform distribution cannot fall off
smoothly to zero. My first idea is to use a 2D-normal distribution and project
it onto the sphere. One can play with the sigma(s) to sharpen the peak and/or
use weighted averages of such distributions.
Best regards,
Michael
Date: 26 Aug 2016 14:05:01
Message: <web.57c083f28629941bb488d9aa0@news.povray.org>
I see the "probability" aspect of this now...
no time to code it at the moment.
define a spline with a probability function
sparse near 0, denser near 1, maybe exponentially peaking at 1
choose rand between 0 and 1
pluck out y value from spline
then it's just a sphere in that y gradient
Date: 26 Aug 2016 16:20:00
Message: <web.57c0a3b08629941b7a3e03fe0@news.povray.org>
> peak.
> zero.
Let me simulate it in Blender. I use a system of particles and particle_map.
We have invented a bicycle.
Blender - your problem?
Date: 26 Aug 2016 16:40:00
Message: <web.57c0a88b8629941bb488d9aa0@news.povray.org>
likely.  ;)
// Log spherical pattern
// Bald Eagle 2016
#version 3.7;
#include "rand.inc"
#declare R = 5;
 location <0, R, -15>
 look_at  <0, R, 0>
#declare Stream2 = seed (456);
#declare Stream3 = seed (789);
#declare Sphere_Spline =
  spline {
    linear_spline
   -0.25, <-0.25, 0.0, 0>,
    0.00, <0.00000000000000000001, 0.0, 0>,
    1.00, <1, 0, 0>
    1.1 , <1.1, 0, 0>
#declare Sphere1 =
union {
    #for (Point, 1, 1000)
        #declare Phi =  RRand(0, 2*pi, Stream);
        #declare Variable2 = RRand(1.00000001, 10, Stream2);
        #declare Theta = -pi*Sphere_Spline(1-log(Variable2))+(pi/2);
    #declare X = R * cos (Theta.x) * sin (Phi);
    #declare Z = R * cos (Theta.x) * cos (Phi);
    #declare Y = R * sin (Theta.x) + R;
    sphere {<X, Y, Z>, 0.01 pigment {Red} }
object {Sphere1}
Date: 26 Aug 2016 17:45:00
Message: <web.57c0b8258629941b7a3e03fe0@news.povray.org>
> likely.  ;)
Tomorrow you will be asked to another location formula. The day after tomorrow
another. In each case the formula. Tired, you want to relax.
I have shown in the screenshots universal way: image_map.
Draw Mandelbrot grayscale on any object - no problem. :)))))
