POV-Ray : Newsgroups : povray.advanced-users : Union of unions and macros Server Time
15 Jun 2024 12:06:03 EDT (-0400)
  Union of unions and macros (Message 1 to 6 of 6)
Subject: Union of unions and macros
Date: 18 Feb 2016 21:51:15
Message: <56c68323$1@news.povray.org>
I have the following bit of code:
union
	#for (i, 1, Trees_Number)
		#local Trees_Object = union
			PlantPatch()
			scale 1/64
		Populate_Triangle(Trees_Object, 1, Seed, Flip)
The result of the PlantPatch() and Populate_Triangle() macros are
additional unions. However, I get the error, "No matching } in 'union',
union found instead". Is there something wrong with the scene? I thought
unions could contain other unions. Thanks.
Mike
Subject: Re: Union of unions and macros
Date: 18 Feb 2016 22:20:36
Message: <56c68a04$1@news.povray.org>
Am 19.02.2016 um 03:51 schrieb Mike Horvath:
> union
>             PlantPatch()
>             scale 1/64
>     #end
You might want to have a closer look at the macros.
Date: 18 Feb 2016 22:43:25
Message: <56c68f5d$1@news.povray.org>
> union
>              PlantPatch()
>              scale 1/64
>      #end
Change PlantPatch to an intersection and Populate_Triangle to a difference.
The object will be broken but it will parse, and that might lead you to
which is your offending macro.  One of those has an extra }
Date: 20 Feb 2016 14:31:18
Message: <56c8bf06$1@news.povray.org>
>> union
>>              PlantPatch()
>>              scale 1/64
>>      #end
Excuse me, but changing an union to an intersection or difference?
There is no way that can give the same result, ever. It will also render
MUCH slower.
My guess is that one of those macros produce an union that may be
missing it's closing brace.
Date: 20 Feb 2016 15:42:12
Message: <56c8cfa4$1@news.povray.org>
> MUCH slower.
No, the point is not to render it, it's just to parse it to figure which
of the 3 nested unions is missing the }.  If one changes a union to a
difference, maybe it says "missing } in difference" and buys one a clue
to where the problem is.
dik
Date: 20 Feb 2016 16:47:30
Message: <56c8def2@news.povray.org>
>> MUCH slower.
> dik
I changed this:
              PlantPatch()
              scale 1/64
to this:
#local Trees_Object = object
              PlantPatch()
              scale 1/64
Now it works. Thanks guys!
Mike
