POV-Ray : Newsgroups : povray.advanced-users : Aerodynamics question Server Time
16 May 2026 23:04:27 EDT (-0400)
  Aerodynamics question (Message 21 to 23 of 23)
Subject: Re: Aerodynamics question
Date: 24 Feb 2015 16:57:15
Message: <54ecf3bb@news.povray.org>
Le 15-02-22 23:12, Mike Horvath a écrit :
> On 2/22/2015 2:28 PM, Alain wrote:
>> Le 15-02-19 03:22, scott a écrit :
>>>> The density of hydrogen atom in outer space is variable, but the
>>>> pressure is in the nano-pascal ( 10^-9 ) range, and we live in
>>>> kilohecto-pascal ( 10^5 ), so the influence of the drag is to be
>>>> corrected by at least something like a 10^-14 factor.
>>> Drag depends on velocity squared, so that would mean if your velocity
>>> was 10^7 times higher than on earth, you would experience a similar
>>> level of drag.
>>> I have no idea what "interstellar velocities are" though, 10^7 or
>>> more? :-)
>> The 10^-9 range is for our spacial neigourhood, or relatively close to a
>> star. As you travel farther, it drops conciderably. Between the Sun and
>> Proxima Centaury, the vacuum around the moon looks like high pressure.
>> In space, to have a drag equivalent to 100 Km/h on a road, using the
>> 10^14 factor for Earth region, you would need to travel at over 100 000
>> 000 000 000 Km/h (10^16 Km/h). That's  /way/ faster than the speed of
>> light ! (about 10^9 Km/h)
>> Alain
> What about within nebulae?
Compared to most nebulaes, the best vacuum attained in the most advanced
laboratories looks like medium to high presure.
So, when traveling at non-relativistic speed, you can normaly totaly
ignore their presence.
Date: 24 Feb 2015 17:03:34
Message: <54ecf536@news.povray.org>
Le 15-02-24 11:53, clipka a écrit :
> Am 24.02.2015 um 17:31 schrieb clipka:
>> Am 19.02.2015 um 09:25 schrieb scott:
>>>> I'm building a bubble around my spaceship to protect from "drag" at
>>>> interstellar velocities. This site says that for subsonic craft a
>>>> parabola is a better shape for the nose. However, an ogive is better at
>>>> supersonic speeds.
>>>> http://www.aerospaceweb.org/question/aerodynamics/q0151.shtml
>>>> Which applies in outer space? Or, should I not use either and use a
>>>> teardrop shape instead?
>>> What is the speed of sound in space... I don't think any "supersonic"
>>> designs are necessary.
>> In an ideal gas, the speed of sound is proportional to the square root
>> of the pressure... until relativistic effects kick in, I guess.
> In numbers: Speed of sound in hydrogen and helium is roughly 10^3 m/s at
> atmospheric pressure. With the pressure in outer space being lower by a
> factor of about 10^14, according to Newtonian mechanics the speed of
> sound in this medium would be about 10^7 times higher, i.e. 10^10 m/s -
> exceeding the speed of light by about 1.5 magnitudes.
That would be inversly proportional.
Date: 26 Feb 2015 13:40:39
Message: <54ef68a7@news.povray.org>
Am 24.02.2015 um 23:04 schrieb Alain:
Whoops - yes. Consider it a typo.
