POV-Ray : Newsgroups : povray.advanced-users : Aerodynamics question Server Time
16 May 2026 21:43:20 EDT (-0400)
  Aerodynamics question (Message 14 to 23 of 23)
Subject: Re: Aerodynamics question
Date: 22 Feb 2015 23:12:18
Message: <54eaa8a2$1@news.povray.org>
On 2/22/2015 2:28 PM, Alain wrote:
> Le 15-02-19 03:22, scott a écrit :
>>> The density of hydrogen atom in outer space is variable, but the
>>> pressure is in the nano-pascal ( 10^-9 ) range, and we live in
>>> kilohecto-pascal ( 10^5 ), so the influence of the drag is to be
>>> corrected by at least something like a 10^-14 factor.
>> Drag depends on velocity squared, so that would mean if your velocity
>> was 10^7 times higher than on earth, you would experience a similar
>> level of drag.
>> I have no idea what "interstellar velocities are" though, 10^7 or
>> more? :-)
> The 10^-9 range is for our spacial neigourhood, or relatively close to a
> star. As you travel farther, it drops conciderably. Between the Sun and
> Proxima Centaury, the vacuum around the moon looks like high pressure.
> In space, to have a drag equivalent to 100 Km/h on a road, using the
> 10^14 factor for Earth region, you would need to travel at over 100 000
> 000 000 000 Km/h (10^16 Km/h). That's  /way/ faster than the speed of
> light ! (about 10^9 Km/h)
> Alain
What about within nebulae?
Date: 23 Feb 2015 03:15:11
Message: <54eae18f@news.povray.org>
On 23-2-2015 5:11, Mike Horvath wrote:
> On 2/22/2015 2:34 PM, Alain wrote:
>> The most realistic space fighter I ever saw was the Fury from Babylon 5.
>> NO wings. No profiling. Just bone dry design with a canopy designed only
>> to provide the largest view field as possible.
> I thought the corvettes from Independence War were pretty cool.
http://static.giantbomb.com/uploads/scale_small/4/48222/1130546-independencewaruscoverxt6.jpg
Yes, both models exemplify the road taken by more modern (and
realistic?) design.
Date: 23 Feb 2015 03:48:12
Message: <54eae94c$1@news.povray.org>
>> Alain
> How the hell did you calculate that? I'm not saying you're wrong -
> you're probably right - but can I see the equations?
Drag force is directly proportional to the fluid density, and velocity
*squared*. So if the density is 10^14 times lower, the velocity "only"
needs to be 10^7 times higher to get the same force. I don't know where
Alain got the 10^16 km/hr from.
But it gets worse, the power (rate of doing work) required to maintain
the velocity against drag equals the drag force times the velocity. So
if you want the same *power* requirement as on Earth, the velocity only
needs to be about 50000 times higher.
Date: 24 Feb 2015 11:27:39
Message: <54eca67b$1@news.povray.org>
Am 22.02.2015 um 20:34 schrieb Alain:
Well, the struts for the Fury's engines sort of /look/ like wings, with
their somewhat horizontal arrangement.
For a space fighter, I guess it would be more reasonable to arrange the
engines in an orthogonal X shape: Both for safety (if one engine fails
catastrophically, you want a maximum distance to the nearest other
engine(s)) and for the sake of being able to effect attitude corrections
by means of variable engine thrust (with an orthogonal arrangement, both
pitch and yaw can be affected equally well, while the "flat" X shape
strongly favors yaw).
Possibly the best compromise between reasonable arrangement and viewer
expectations would be a 3-engine design with an upside-down Y configuration.
Date: 24 Feb 2015 11:31:36
Message: <54eca768$1@news.povray.org>
Am 19.02.2015 um 09:25 schrieb scott:
>> I'm building a bubble around my spaceship to protect from "drag" at
>> interstellar velocities. This site says that for subsonic craft a
>> parabola is a better shape for the nose. However, an ogive is better at
>> supersonic speeds.
>> http://www.aerospaceweb.org/question/aerodynamics/q0151.shtml
>> Which applies in outer space? Or, should I not use either and use a
>> teardrop shape instead?
> What is the speed of sound in space... I don't think any "supersonic"
> designs are necessary.
In an ideal gas, the speed of sound is proportional to the square root
of the pressure... until relativistic effects kick in, I guess.
Date: 24 Feb 2015 11:53:42
Message: <54ecac96$1@news.povray.org>
Am 24.02.2015 um 17:31 schrieb clipka:
>>> supersonic speeds.
In numbers: Speed of sound in hydrogen and helium is roughly 10^3 m/s at
atmospheric pressure. With the pressure in outer space being lower by a
factor of about 10^14, according to Newtonian mechanics the speed of
sound in this medium would be about 10^7 times higher, i.e. 10^10 m/s -
exceeding the speed of light by about 1.5 magnitudes.
Date: 24 Feb 2015 16:53:14
Message: <54ecf2ca$1@news.povray.org>
>> Alain
> John
The speed of light is a little under 300 000 Km/s. Multiply that by
3600, the number of seconds in an hour, gives about 1 080 000 000 Km/h
whitch is somewhat larger than the true speed of light in a vacuum, that
I rounded down: 10^9
Next, I used the appriximative presure ratio between sea level and space
"vacuum" in Earth vicinity: 10^14 to 1.
Finaly, I multiplied that with a speed of 100 Km/h (about 60 Miles per
hour), or highway speed: 10^16
That's around 10 000 000 times the speed of light! In StarTreck second
generation universe, that's warp 7, or a ludicrous warp 10 millions in
the original.
As I'm only concerned with the order of magnitude, the approximations
are acceptable.
Date: 24 Feb 2015 16:57:15
Message: <54ecf3bb@news.povray.org>
>>> level of drag.
>>> more? :-)
>> Alain
Compared to most nebulaes, the best vacuum attained in the most advanced
laboratories looks like medium to high presure.
So, when traveling at non-relativistic speed, you can normaly totaly
ignore their presence.
Date: 24 Feb 2015 17:03:34
Message: <54ecf536@news.povray.org>
>>>> supersonic speeds.
That would be inversly proportional.
Date: 26 Feb 2015 13:40:39
Message: <54ef68a7@news.povray.org>
Am 24.02.2015 um 23:04 schrieb Alain:
Whoops - yes. Consider it a typo.
