POV-Ray : Newsgroups : povray.advanced-users : Constraining an image map to a certain region of a sphere? Server Time
28 Sep 2024 15:04:06 EDT (-0400)
  Constraining an image map to a certain region of a sphere? (Message 1 to 4 of 4)
Subject: Constraining an image map to a certain region of a sphere?
Date: 20 Jul 2013 04:51:30
Message: <51ea4f92$1@news.povray.org>
Hi(gh)!
The problem: I want to project a square image_map, which is a
heightfield covering one square degree of ASTER elevation data, onto a
sphere, not onto the entire sphere, but instead onto the geographic
coordinate range defined by the elevation data tile.
shall have the texture, all other parts of the sphere shall remain
textureless.
To avoid misunderstanding: I do not want to create a curved
"heightfield" (this I already have achieved), but a "geographically"
constrained pigment function which then will be used for an isosurface.
Is this doable at all with POV-Ray? Obviously, Christoph Hormann must
have done it with the terrain renderings on his "Imagico" pages:
http://earth.imagico.de/technical.php
I can't imagine that he used an isosurface covering the entire Earth, as
billions of height data points would have to be processed, which simply
would be beyond the capacities of today's PCs...
See you in Khyberspace!
Yadgar
Subject: Re: Constraining an image map to a certain region of a sphere?
Date: 20 Jul 2013 04:58:06
Message: <51ea511e@news.povray.org>
> Hi(gh)!
> textureless.
applying spherical warp to a scaled-down version of the image map (with
the "once" keyword) might do the trick.
Date: 20 Jul 2013 12:38:34
Message: <51eabd0a$1@news.povray.org>
>> Hi(gh)!
>> textureless.
Next, you may translate verticaly to apply the image to the correct
latitude: translate sin(radians(Latitude))*y. For the longitude, a
simple rotate Longitude*y will do.
Date: 20 Jul 2013 17:18:21
Message: <51eafe9d$1@news.povray.org>
Hi(gh)!
Yes, it does! Here is what I programmed after your post:
// begin of code
#declare lat=0;
#declare long=20;
sphere
   0, 1
   texture
     pigment
       color rgb <0, 0, 1>
   texture
     pigment
       image_map
         png "testimg.png"
         interpolate 2
         once
       scale <1/360, 1/180, 1>
       translate <(180+long)/360, (90+lat)/180, 0>
       warp
         spherical
         orientation z
         dist_exp 0
       rotate <0, 90, 0>
light_source
   <0, 0, 1000>
   color rgb 1
camera
   location <0, 0, 4>
   look_at 0
// end of code
This worked fine... but when I tried to use this pigment as an
isosurface function (yes, of course subtracted from a sphere function!),
all I got was a featureless sphere, only a hint of relief visible at the
terminator (grainy shadows) which, on the other hand, indicates that the
function was *not* constrained to a defined geographical region on the
sphere! Strange!
(as this is not a binary group, I added a f'up to p.b.i)
Yadgar
Now playing: My Own Way, album version (Duran Duran)
