POV-Ray : Newsgroups : povray.advanced-users : Left & Right ? Server Time
16 May 2026 21:24:09 EDT (-0400)
  Left & Right ? (Message 1 to 5 of 5)
Subject: Left & Right ?
Date: 13 Aug 2012 22:30:18
Message: <5029b83a@news.povray.org>
Hay,
  What is the easiest(fastest) way to calculate if a point is left or
right from your position? Given just two vectors the one your at and the
one you want to check. While using <0,0,0> & your position vector for
the direction your 'looking at'.
           A
0---at-
           B
Subject: Re: Left & Right ?
Date: 14 Aug 2012 02:02:30
Message: <5029e9f6$1@news.povray.org>
Le 14/08/2012 04:30, Leroy a écrit :
> Hay,
>           A
> 0---at-
>           B
Is that 2D or 3D ?
V1: vector/point you are looking at from origin.
V2: vector/relative position of a point X from origin
in 3D:
 You are missing at least another vector to define the "up".
 If your vector V1 was not a direction you are looking at, but the
oriented normal of the splitting plane, you would have enough data (and
could use the solution of 2D). Vector N is the dot product of V1 and Up.
in 2D:
 I assume you are at <0,0>, and you are looking at V1, left or right for
X is best computed as the sign of the cross product.
And yes, there is a plane in which left/right has no meaning, the
symmetry plane.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 14 Aug 2012 12:12:55
Message: <502a7907@news.povray.org>
>> Hay,
>>           A
>> 0---at-
>>           B
> Is that 2D or 3D ?
Yes :)
I got into the habit of working out problems like this in 2d the
expanding the solution to 3D. For most things 2D acts like a plane in 3D.
> in 3D:
  Your Right! Another habit of using Y as 'up' everywhere.
  Lets see, I have played around with normals and planes. Its a point
perpendicular to a plane at <0,0,0>,it defines a plane in POV. I have no
idea what the 'splitting plane' is!  I think you mean the plane dividing
left and right. The dot product of (V1,Up) is a float!? I don't
understand 'Vector N'.
> in 2D:
This probably is the answer I was thinking of when I asked the question!
> symmetry plane.
Symmetry Plane!? I'll have to google that.
Thank for your help.
Have Fun!
Date: 14 Aug 2012 15:39:34
Message: <502aa976@news.povray.org>
Le 14/08/2012 18:12, Leroy nous fit lire :
>>> Hay,
>>>           A
>>> 0---at-
>>>           B
>> Is that 2D or 3D ?
> Yes :)
>> in 3D:
> left and right.
Correct.
My bad. it is the cross product of N := V1 x Up
I have inversed the whole naming (not native English)
>> in 2D:
You want to know the projection of V2 on N. (only the sign) of the dot
product N . V2
So compute (V1 x Up) . V2
(or whatever order you want. V2 . ( Up x V1 ), there is 2 additional
permutations, also valid (but the resulting sign might change, so stick
to one formula once chosen))
x : cross product (give a vector)
. : dot product (give  a scalar)
The sign is a local convention, there is no way to define left & right
on transmission with an alien of a remote universe.
Date: 16 Aug 2012 12:51:49
Message: <502d2525@news.povray.org>
No problem! I do it all the time and English IS my native language.
This makes more sense. I've might have caught it myself if I know more
about vectors.
Thanks, The rest of you post answers my question fully.
Have Fun!
