POV-Ray : Newsgroups : povray.advanced-users : Paraboloid Server Time
29 Mar 2026 23:13:27 EDT (-0400)
  Paraboloid (Message 1 to 9 of 9)
Subject: Paraboloid
Date: 23 Jun 2011 22:03:54
Message: <4e03f08a@news.povray.org>
How do I create a paraboloid where a slice through the object produces a
circle of a fixed and known size? Thanks!
Mike
http://isometricland.com
Subject: Re: Paraboloid
Date: 24 Jun 2011 03:05:05
Message: <4e043721$1@news.povray.org>
Slice of paraboloid are circle only when the slice is perpendicular to
the axis of the paraboloid.
Ergo, if the slice is parallel to the z plane, the circle will be
a.(x²+y²) - b = 0
a.(x²+y²) is the square of the radius (r² := b).
If the equation of your paraboloid is (classical) z=k.(x²+y²), it seems
obvious that the slice must have a z so that k.(x²+y²) is the square of
the desired radius.
(i.e. #local z_position = sqrt( pow(r,2)/k );  )
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 24 Jun 2011 09:51:36
Message: <4e049668@news.povray.org>
> a.(x²+y²) - b = 0
> the desired radius.
Oups,
it's z_position = pow(r,2)/k;
Simpler that way.
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec.  Working<br/>
late would feel like using an undocumented external procedure.
Date: 24 Jun 2011 15:07:57
Message: <4e04e08d$1@news.povray.org>
But, what is k?
Date: 24 Jun 2011 15:47:38
Message: <4e04e9da$1@news.povray.org>
> But, what is k?
Nevermind, got it to work. Thanks!!
Date: 24 Jun 2011 15:48:51
Message: <4e04ea23@news.povray.org>
> But, what is k?
Here's my POV code:
#include "shapes.inc"
#local p_radius = 2;
#local p_scale = 2;
#local z_position = pow(p_radius,2)/p_scale;
intersection
	object
		Paraboloid_Z
		scale p_scale
	plane {+z,z_position}
	pigment {color rgb 1}
cylinder
	0, z*1, p_radius
	translate z*z_position
Date: 26 Jun 2011 11:34:54
Message: <4e07519e$1@news.povray.org>
> Mike
OK, next challenge: the focus of the parabola must be located at the
center of the circle! I want to create a solar collector and need to
know the precise dimensions beforehand.
Date: 26 Jun 2011 11:47:28
Message: <4e075490$1@news.povray.org>
Le 26/06/2011 17:34, posfan12 nous fit lire :
>> Mike
http://en.wikipedia.org/wiki/Parabola
focus at <0,0,1/(4*k)>
for equation of paraboloid z= k(x²+y²)
Date: 26 Jun 2011 12:25:50
Message: <4e075d8e$1@news.povray.org>
> focus at<0,0,1/(4*k)>
If you could use/modify the POV code in my previous post I would greatly
appreciate it, thank you.
Mike
