POV-Ray : Newsgroups : povray.advanced-users : Tangent to two ellipses? Server Time
9 Jun 2026 23:45:27 EDT (-0400)
  Tangent to two ellipses? (Message 11 to 16 of 16)
Subject: Re: Tangent to two ellipses?
Date: 18 Oct 2010 17:09:42
Message: <4cbcb796@news.povray.org>
Tim Cook wrote:
> I have a spline which I which to simplify to a series of CSGed cylinders
> and boxes.
> cylinder 1 is located at 0, 0 with major and minor axes of 2 and 1.4375
> cylinder 2 is located at 0.5, 2.875 with maj./min. axes of 1.786, 1.03125
> How do I find the endpoints of the tangent ascending from the left of
> the lower circle to the right of the upper circle?
> (Also on this spline is needed a tangent descending from the left of the
> lower circle to intersect point -2.03125, 0.21875, the method of
> solution of which is probably related to the other problem)
This part if simpler, for the ellipse defined as
x(t)=a*cos(t)+x0;
y(t)=b*sin(t)+y0;
x0=0;
y0=0;
px=-2.03125;
py= 0.21875;
dx=x0-px;
dy=y0-py;
D=(a^2*dy^2-b^2*a^2+dx^2*b^2);
t=atan2(-(a^2*dy^2+dx*dy*D^(1/2))*b, a*(-dx*b^2+dy*D^(1/2))*dy)+pi;
s=atan2(-(a^2*dy^2-dx*dy*D^(1/2))*b, a*(-dx*b^2+dy*D^(1/2))*dy)+pi;
the point on the ellipse for the tangent line
you need through the point (px,py) would be
Q=(x(s),y(s)) = (-1.87534111088024,0.499567815891366)
As for the tangent to two ellipses
xt(t)=a*cos(t)+xt0;
yt(t)=b*sin(t)+yt0;
xs(s)=c*cos(s)+xs0;
ys(s)=d*sin(s)+ys0;
there are two constrains for two unknowns t and s:
tan_ell1 = (+/-) tan_ell2
tan_ell1 =  tan_line
the second parameter s is dependent on t:
s=arctan((+/-)a*d*tan(t)/(b*c));
finally it boils out to a single non-linear equation in t
(ys(s)-yt(t))/(xs(s)-xt(t))= (+/-) b/a/tan(t)
Maple gives an analytic solution, but it is unreasonably long.
Two points to take care of: signs and (+/-) pi to the value of arctangent.
Download 'el00.pdf' (5 KB)
Date: 20 Oct 2010 06:27:52
Message: <4cbec428@news.povray.org>
> No, an ellips is not an unevenly scalled circle. It's close but not quite
> the same.
I always thought an ellipse was exactly the same as an unevenly scaled
circle, what's the difference?
Date: 20 Oct 2010 16:43:46
Message: <4cbf5482$1@news.povray.org>
>> quite the same.
I remember a tread some times ago where it was discuced. Along the major
and minor axis, there is no difference, but about midway, there is a
very slight difference that was effectively demonstrated graphicaly
using a scaled sphere and an ellipse made using the analytic formula for
an isosurface.
When rendered coincidently, using distinct pigments for the scaled
sphere and the isosurface, there was almost no coincident surfaces
artefacts, but clearly one or the other pigment visible.
There was also a discussion about elliptical torus also showing that
slight difference.
Anyway, the difference is prety small and, for all practical purposes,
can be dismissed.
Date: 20 Oct 2010 17:46:36
Message: <4cbf633c@news.povray.org>
actually, I think this just demonstrates you shouldn't
use a raytracer to prove mathematical theorems ;) As Warp
already mentioned the formula for an ellipse is just that
of a circle with non-uniform scaling applied to x and y,
so mathematically it should be identical. But numerical
solving may overswing in a systematic manner depending
on curvature and whatnot.
Date: 28 Oct 2010 19:06:56
Message: <4cca0210$1@news.povray.org>
A bit of research and fiddling later, I now have a simpler method for
calculating the angle of tangency for a given point on an ellipse that
doesn't even involve math beyond basic trig or terribly long equations.
  It turns out that you can use the fact that an ellipse is just a
squashed circle to do some indirect figuring.
Given unrotated ellipse at <x,y> with radii <a,b> and an angle T:
Point P <c,d> on ellipse is <a*cos(T)+x,b*sin(T)+y>
Tangent angle at P is:
If major axis is along x, atan2(d,a/cos(T)-c)
If major axis is along y, atan2(b/cos(90-T)-d,c)
That's it.
Now all I need to do is find at what angles for two ellipses the
equations for the lines are the same.
Tim Cook
Date: 29 Oct 2010 00:33:10
Message: <4cca4e86$1@news.povray.org>
err add x and y after using the point for the tangent calculations
Tim Cook
http://empyrean.freesitespace.net
