POV-Ray : Newsgroups : povray.advanced-users : Improving media performance Server Time
15 Jun 2026 07:06:21 EDT (-0400)
  Improving media performance (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Improving media performance
Date: 27 Jun 2010 11:58:17
Message: <4c277519$1@news.povray.org>
On 6/26/2010 1:59 PM, Alain wrote:
> Not for the presure.
> As the air in the center may, under some conditions, rotate slightly
> faster than the station, the presure *will* diminishes from the surface
> toward the center.
> BUT, as the radius is /only/ 1 Km and quite probably a rim gravity less
> than Earth's gravity, the presure gradient will be relatively small,
> possibly small enough to be neglected. Maybe in the order of 2% or 3%.
> After all, you realy don't need a full Earth gravity, something between
> 0.5G and 0.7G should be enough.
> Alain
If I remove the density map, will rendering times change? Also, how
should I specify the media's density when the pattern is absent?
http://isometricland.com
Date: 27 Jun 2010 13:23:57
Message: <4c27892d$1@news.povray.org>
>> toward the center.
>> Alain
You may not need as many samples, whitch will make things go faster.
NEVER use intervals and only use samples. It's MUCH faster.
Set your media base density. The density from the map get multiplied
with it.
scattering{1, rgb 0.01,.....}
Change the rgb value.
Date: 27 Jun 2010 17:16:07
Message: <4c27bf97$1@news.povray.org>
> with it.
> Alain
I'll try that then.
OT - Too bad we don't have a GasSys include like we have a LightSys one! :)
Date: 27 Jun 2010 18:02:06
Message: <4c27ca5e@news.povray.org>
Am 27.06.2010 17:58, schrieb SharkD:
It's worth a try at least. As for the density, just specify none. All
you use to control the constant density is the parameter after the
"emission", "absorption" or "scattering" keyword.
Date: 28 Jun 2010 16:17:39
Message: <4c290363$1@news.povray.org>
No such luck.
It still drops render times to the pixels-per-minute range.
Date: 29 Jun 2010 21:57:49
Message: <4c2aa49d$1@news.povray.org>
> No such luck.
Try with less samples. Uniform media usualy need less samples. Don't set
intervals but leave it to default = 1.
Date: 29 Jun 2010 22:18:21
Message: <4c2aa96d@news.povray.org>
> Alain
Samples right now are at their defaults. Should I use values smaller than 1?
Date: 30 Jun 2010 14:12:58
Message: <4c2b892a$1@news.povray.org>
>> Alain
> than 1?
Try samples 5.
A value of zero or negative don't make any sence, and should'nt work.
Date: 3 Jul 2010 12:06:37
Message: <4c2f600d@news.povray.org>
On 6/30/2010 2:12 PM, Alain wrote:
> Try samples 5.
> Alain
I'm using the defaults which are 1,1. Can I go lower than that?
Date: 3 Jul 2010 22:15:54
Message: <4c2feeda@news.povray.org>
>> Try samples 5.
>> Alain
samples 1,1 may have been the default for method 1.
The default method 3 only use a single samples value. If there is a
second value present, it's ignored.
samples 1 is the lowest you can go. That mean that you only ever take a
single sample of your media.
