POV-Ray : Newsgroups : povray.advanced-users : Improving media performance Server Time
15 Jun 2026 07:06:21 EDT (-0400)
  Improving media performance (Message 11 to 16 of 16)
Subject: Re: Improving media performance
Date: 28 Jun 2010 16:17:39
Message: <4c290363$1@news.povray.org>
On 6/27/2010 6:01 PM, clipka wrote:
> Am 27.06.2010 17:58, schrieb SharkD:
>> If I remove the density map, will rendering times change? Also, how
>> should I specify the media's density when the pattern is absent?
> It's worth a try at least. As for the density, just specify none. All
> you use to control the constant density is the parameter after the
> "emission", "absorption" or "scattering" keyword.
No such luck.
It still drops render times to the pixels-per-minute range.
http://isometricland.com
Date: 29 Jun 2010 21:57:49
Message: <4c2aa49d$1@news.povray.org>
> No such luck.
Try with less samples. Uniform media usualy need less samples. Don't set
intervals but leave it to default = 1.
Date: 29 Jun 2010 22:18:21
Message: <4c2aa96d@news.povray.org>
> Alain
Samples right now are at their defaults. Should I use values smaller than 1?
Date: 30 Jun 2010 14:12:58
Message: <4c2b892a$1@news.povray.org>
>> Alain
> than 1?
Try samples 5.
A value of zero or negative don't make any sence, and should'nt work.
Date: 3 Jul 2010 12:06:37
Message: <4c2f600d@news.povray.org>
On 6/30/2010 2:12 PM, Alain wrote:
> Try samples 5.
> Alain
I'm using the defaults which are 1,1. Can I go lower than that?
Date: 3 Jul 2010 22:15:54
Message: <4c2feeda@news.povray.org>
>> Try samples 5.
>> Alain
samples 1,1 may have been the default for method 1.
The default method 3 only use a single samples value. If there is a
second value present, it's ignored.
samples 1 is the lowest you can go. That mean that you only ever take a
single sample of your media.
