![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've written the following macro to tweak some color values:
#macro gamma_color_adjust(in_color, in_transmit)
#local out_gamma = 2.2;
#if (in_transmit)
VPow(in_color,out_gamma) + <0,0,0,in_transmit,>
#else
The macro takes a three component color vector as the first parameter,
and a single transmit parameter as the second parameter. I keep getting
the error, "Expected 6 parameters but only 5 found." What did I do wrong?
http://isometricland.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 09.06.2010 23:22, schrieb SharkD:
> #if (in_transmit)
> #else
> #end
> #end
Not sure what's wrong there (sounds pretty strange), but I suggest a
different approach to the macro anyway:
#macro Gamma_Adjust(In_Color)
#local Out_Gamma = 2.2;
rgbft <
pow(In_Color.red, Out_Gamma),
pow(In_Color.green, Out_Gamma),
pow(In_Color.blue, Out_Gamma),
In_Color.filter,
In_Color.transmit
Using three separate calls to pow isn't any slower than VPow (actually
it's faster, because VPow is just another macro that itself calls pow
thrice), and you also don't need separate parameters; just replace (e.g.)
color rgbt <R,G,B,T>
with
color Gamma_Adjust( rgbt <R,G,B,T> )
It should work with any color literal syntax you can imagine, such as
"color red R", "color rgb GREY filter F", "color rgbft <R,G,B,F,T>", or
what-have-you.
(BTW, I suggest using Mixed_Case identifiers for anything you name
yourself, as lower_case identifiers pose a risk of conflicting with
future SDL keywords.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> #if (in_transmit)
> #else
> #end
> #end
I didn't try it, but I noticed that there is a trailing comma after in_transmit,
which could make povray think that there should be another value. If this is a
direct copy&paste, double check that comma.
HTH
-Reactor
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> HTH
> -Reactor
IIRC, trailing commas after vector components are legal. I will try
without though.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> what-have-you.
It didn't work for me, in 3.6 at least. Example:
rgbft <
In_Color.filter,
In_Color.transmit
#declare test_color = Gamma_Adjust(<1,1,1>);
Results in an "Bad operands for period operator" error.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"SharkD" <pos### [at] gmail com> schreef in bericht
news:4c102e92$1@news.povray.org...
You certainly have seen my thread in povray.general: "Bad operands", on
20-5-2010? :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 10.06.2010 02:15, schrieb SharkD:
>> what-have-you.
<1,1,1> is not a color (=5D vector), but a 3D vector. Try this instead:
#declare test_color = Gamma_Adjust( rgb <1,1,1> );
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 6/10/2010 3:04 AM, Thomas de Groot wrote:
> "SharkD"<pos### [at] gmail com> schreef in bericht
> 20-5-2010? :-)
> Thomas
No, I didn't. Was the problem ever resolved?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I changed the macro to this and it seems to work OK:
#macro gamma_color_adjust(in_color)
#local in_color = in_color + <0,0,0,0,0>;
pow(in_color.red, out_gamma),
pow(in_color.green, out_gamma),
pow(in_color.blue, out_gamma),
in_color.filter,
in_color.transmit
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:4c11ae92@news.povray.org...
Yes. Clipka explained it all very well there.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
