POV-Ray : Newsgroups : povray.advanced-users : Problems with macro (3.6) Server Time
11 Oct 2025 15:03:55 EDT (-0400)
  Problems with macro (3.6) (Message 1 to 10 of 10)
Subject: Problems with macro (3.6)
Date: 9 Jun 2010 17:22:25
Message: <4c100611$1@news.povray.org>
I've written the following macro to tweak some color values:
#macro gamma_color_adjust(in_color, in_transmit)
	#local out_gamma = 2.2;
	#if (in_transmit)
		VPow(in_color,out_gamma) + <0,0,0,in_transmit,>
	#else
The macro takes a three component color vector as the first parameter,
and a single transmit parameter as the second parameter. I keep getting
the error, "Expected 6 parameters but only 5 found." What did I do wrong?
http://isometricland.com
Subject: Re: Problems with macro (3.6)
Date: 9 Jun 2010 18:40:00
Message: <4c101840$1@news.povray.org>
Am 09.06.2010 23:22, schrieb SharkD:
> #if (in_transmit)
> #else
> #end
> #end
Not sure what's wrong there (sounds pretty strange), but I suggest a
different approach to the macro anyway:
     #macro Gamma_Adjust(In_Color)
     #local Out_Gamma = 2.2;
       rgbft <
         pow(In_Color.red,   Out_Gamma),
         pow(In_Color.green, Out_Gamma),
         pow(In_Color.blue,  Out_Gamma),
         In_Color.filter,
         In_Color.transmit
Using three separate calls to pow isn't any slower than VPow (actually
it's faster, because VPow is just another macro that itself calls pow
thrice), and you also don't need separate parameters; just replace (e.g.)
     color rgbt <R,G,B,T>
with
     color Gamma_Adjust( rgbt <R,G,B,T> )
It should work with any color literal syntax you can imagine, such as
"color red R", "color rgb GREY filter F", "color rgbft <R,G,B,F,T>", or
what-have-you.
(BTW, I suggest using Mixed_Case identifiers for anything you name
yourself, as lower_case identifiers pose a risk of conflicting with
future SDL keywords.)
Date: 9 Jun 2010 18:55:01
Message: <web.4c101ab385f50d43e69105fc0@news.povray.org>
>  #if (in_transmit)
>  #else
>  #end
> #end
I didn't try it, but I noticed that there is a trailing comma after in_transmit,
which could make povray think that there should be another value.  If this is a
direct copy&paste, double check that comma.
    HTH
-Reactor
Date: 9 Jun 2010 19:51:25
Message: <4c1028fd$1@news.povray.org>
>      HTH
> -Reactor
IIRC, trailing commas after vector components are legal. I will try
without though.
Date: 9 Jun 2010 20:15:14
Message: <4c102e92$1@news.povray.org>
> what-have-you.
It didn't work for me, in 3.6 at least. Example:
       rgbft <
         In_Color.filter,
         In_Color.transmit
     #declare test_color = Gamma_Adjust(<1,1,1>);
Results in an "Bad operands for period operator" error.
Date: 10 Jun 2010 03:04:21
Message: <4c108e75$1@news.povray.org>
"SharkD" <pos### [at] gmailcom> schreef in bericht
news:4c102e92$1@news.povray.org...
You certainly have seen my thread in povray.general: "Bad operands", on
20-5-2010?  :-)
Date: 10 Jun 2010 07:58:56
Message: <4c10d380@news.povray.org>
Am 10.06.2010 02:15, schrieb SharkD:
>> what-have-you.
<1,1,1> is not a color (=5D vector), but a 3D vector. Try this instead:
    #declare test_color = Gamma_Adjust( rgb <1,1,1> );
Date: 10 Jun 2010 23:33:38
Message: <4c11ae92@news.povray.org>
On 6/10/2010 3:04 AM, Thomas de Groot wrote:
> "SharkD"<pos### [at] gmailcom>  schreef in bericht
> 20-5-2010?  :-)
> Thomas
No, I didn't. Was the problem ever resolved?
Date: 10 Jun 2010 23:57:37
Message: <4c11b431@news.povray.org>
I changed the macro to this and it seems to work OK:
#macro gamma_color_adjust(in_color)
	#local in_color = in_color + <0,0,0,0,0>;
		pow(in_color.red, out_gamma),
		pow(in_color.green, out_gamma),
		pow(in_color.blue, out_gamma),
		in_color.filter,
		in_color.transmit
Date: 11 Jun 2010 03:21:37
Message: <4c11e401@news.povray.org>
news:4c11ae92@news.povray.org...
Yes. Clipka explained it all very well there.
