POV-Ray : Newsgroups : povray.advanced-users : Converting pre-gamma scenes to assumed_gamma = 1? Server Time
9 Jun 2026 17:25:24 EDT (-0400)
  Converting pre-gamma scenes to assumed_gamma = 1? (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Converting pre-gamma scenes to assumed_gamma = 1?
Date: 9 Jun 2010 15:57:18
Message: <4c0ff21e$1@news.povray.org>
On 6/9/2010 7:26 AM, clipka wrote:
> (2) Gamma-adjust all color literals, by raising the R,G,B components to
> the power of 2.2 (or wait for the next beta, and add "gamma 2.2" to the
> color literal). Check your scene for colour values that are computed
> from some other values - you may (or may not) want to gamma-adjust these
> as well.
Are you sure about raising to a power? Old scenes are generally brighter
in 3.7 than they were originally, so wouldn't you want to lower them
instead?
http://isometricland.com
Date: 9 Jun 2010 17:04:18
Message: <4c1001d2$1@news.povray.org>
Am 09.06.2010 21:57, schrieb SharkD:
>> as well.
> instead?
Yes, I am sure; note that raising values between 0.0 and 1.0 to some
power > 1 does actually give you smaller values (e.g. 0.50^2 = 0.25).
Date: 9 Jun 2010 17:08:13
Message: <4c1002bd$1@news.povray.org>
Am 09.06.2010 21:42, schrieb SharkD:
> Mind if I copy your post to the wiki?
The idea already crossed my mind, too - so as I currently don't find the
time myself, by all means go ahead.
Date: 9 Jun 2010 17:33:21
Message: <4c1008a1@news.povray.org>
>>> as well.
>> instead?
Oh, OK! Just tested it and everything looks good so far.
Date: 9 Jun 2010 19:54:09
Message: <4c1029a1$1@news.povray.org>
Am 09.06.2010 13:26, schrieb clipka:
> If you do want to port the scene to the right math, here's what I expect
> to be the most important steps:
I just recalled another thing:
You may want to check your adc_bailout setting; in darker scenes, the
current defaults may still be too high and cause visible artifacts.
(I think the adc_bailout mechanism actually needs an overhaul to better
suit proper gamma handling as well as HDR output; I don't think it will
be too easy though.)
Date: 17 Aug 2010 19:35:17
Message: <4c6b1cb5@news.povray.org>
> as well.
What about colors like <1,1,1> or <1,0,0>? Raising them to a power has
no effect.
Date: 17 Aug 2010 19:59:41
Message: <4c6b226d$1@news.povray.org>
>> as well.
> no effect.
And there are also cases where assumed_gamma was (ab)used instead of
ajusting the lights intencity or the finish. Like: My scene is to
dark/bright, don't bother looking at the lights/finishes/pigments,
change assumed_gamma to compensate.
Often, you'll need to adjust the falues of the light_source as well as
the pigments and textures.
Date: 20 Aug 2010 18:01:48
Message: <4c6efb4c$1@news.povray.org>
Am 18.08.2010 01:35, schrieb SharkD:
>> as well.
> no effect.
Exactly. Gamma adjustment affects midtones, but does not change the
maximum brightness.
Date: 20 Aug 2010 19:02:47
Message: <4c6f0997$1@news.povray.org>
> Alain
I've been doing some systematic tests and tweaks. So far I can reproduce
the appearance of pre-assumed_gamma scenes in scenes with assumed_gamma
= 1 in cases where the following parameters vary:
1. lighting color
2. pigment color
3. ambient (finish, not global_settings)
4. diffuse
I haven't figured out filter and transmit yet. I'm guessing it will
require replacing the linear pigment/gradient functions in the original
scenes with exponential ones.
Date: 21 Aug 2010 14:43:02
Message: <4c701e36@news.povray.org>
>> Alain
> 1. lighting color
> 2. pigment color
> 4. diffuse
You probably don't need to change the filter and transmit values.
