POV-Ray : Newsgroups : povray.advanced-users : Image alpha channel without pigment? Server Time
8 Feb 2026 15:22:21 EST (-0500)
  Image alpha channel without pigment? (Message 1 to 2 of 2)
Subject: Image alpha channel without pigment?
Date: 30 Mar 2010 12:04:36
Message: <4bb22114$1@news.povray.org>
I'm currently using some functions that someone here wrote (sorry,
forget who) for scaling the pigments loaded a file (applying a hue,
etc), but I find that this method seems to completely strip any alpha
data that the image could have had.
What I'm wondering is if I can somehow either not strip this alpha data
and still be able to do mathematical functions on the raw rgb values, or
apply an alpha channel from an image to an existing pigment_map? I am
able to apply a pigment-wide transmit value, but I need to be able to
change the alpha based on position.
The pigments are used in uv mapped textures, if that makes any
difference. The scaling code I'm using is as follows:
//The parts in the #if(scale2.t>0) blocks are my attempt at not removing
  the alpha channel if it exists, but it didn't work.
#macro from_black(COLOR)
color_map
   [0 color rgb <0,0,0>]
   [1 color COLOR]
#macro pigment_scale(PIGMENT, SCALE)
#local scale2 = SCALE+<0,0,0,0>;
#local F = function { pigment {PIGMENT} }
#if(scale2.t>0)
   #local mult=4;
#else
   #local mult=3;
#local R = pigment {function {F(x,y,z).red}
from_black(mult*SCALE*<1,0,0>) }
#local G = pigment {function {F(x,y,z).green}
from_black(mult*SCALE*<0,1,0>) }
#local B = pigment {function {F(x,y,z).blue}
from_black(mult*SCALE*<0,0,1>) }
#local T = pigment { color rgbt mult*<0,0,0,scale2.t>}
#if(scale2.t>0)
   pigment {average pigment_map {[R] [G] [B] [T]} }
#else
   pigment {average pigment_map {[R] [G] [B]}}
#declare deftexmult = <0.6,0.6,0.6>;
#macro tga_scale(IMAGE,SCALE)
   #local imagemap = pigment{
     image_map{
       tga IMAGE
       map_type 0
       interpolate 2
       #if(scale2.t>0)
         transmit all scale2.t
//      #debug concat("transmit all ",str(scale2.t,1,2),"\n")
   pigment_scale(imagemap,scale2)
Subject: Re: Image alpha channel without pigment?
Date: 30 Mar 2010 12:19:55
Message: <4bb224ab$1@news.povray.org>
Forgot to mention that the .tga images I'm using do have an alpha
channel and it works if I just include them in a normal
pigment{image_map{}} block, so it's not an issue with them not being the
right format or povray not being able to read the channel.
Chris
