POV-Ray : Newsgroups : povray.advanced-users : Inverse of matrix? Server Time
14 Mar 2026 19:19:21 EDT (-0400)
  Inverse of matrix? (Message 1 to 9 of 9)
Subject: Inverse of matrix?
Date: 14 Nov 2009 23:27:52
Message: <4aff8348@news.povray.org>
I have a matrix:
matrix
	CamR.x, CamR.y, CamR.z,
	CamU.x, CamU.y, CamU.z,
	CamD.x, CamD.y, CamD.z,
	CamL.x, CamL.y, CamL.z
What is the inverse?
Thanks.
Mike
Subject: Re: Inverse of matrix?
Date: 15 Nov 2009 02:45:44
Message: <4affb1a8@news.povray.org>
On 11/14/2009 11:27 PM, SharkD wrote:
> I have a matrix:
> matrix
> Thanks.
> Mike
Nevermind. I found some code to do it here:
http://www.euclideanspace.com/maths/algebra/matrix/functions/inverse/index.htm
Do I need to flip the POV-Ray matrix first? In POV-Ray, translation
occurs in the last *row*, whereas in the page I linked to translation
occurs in the last *column*.
Mike
Date: 15 Nov 2009 02:54:50
Message: <4affb3ca$1@news.povray.org>
> Mike
Also, when applying the matrix to a vector instead of an object (i.e.
using an array), do I multiply by a 1x3 matrix? Is this matrix vertical
or horizontal?
Mike
Date: 15 Nov 2009 05:52:37
Message: <4affdd75$1@news.povray.org>
SharkD schrieb:
> I have a matrix:
> matrix
transform {
   matrix <
   inverse
:-P
Date: 15 Nov 2009 15:00:23
Message: <4b005dd7@news.povray.org>
On 11/15/2009 5:51 AM, clipka wrote:
> :-P
OK, wow. That was easy!
However, I still need to know how to apply the matrix to a coordinate or
vector as opposed to an object.
Mike
Date: 15 Nov 2009 15:31:46
Message: <4b006532$1@news.povray.org>
>> :-P
#declare MyTransform = transform {
   matrix < ... >
#declare MyInverseTransform = transform {
   MyTransform // or directly specify the matrix here
   inverse
#include "transforms.inc"
#declare V2 = vtransform(V1, MyInverseTransform)
// or:
// #declare V2 = vinv_transform(V1, MyTransform)
(When applying the matrix to a direction vector - as opposed to a
location vector, i.e. a point - make sure the matrix doesn't have a
translation component, unless you're perfectly sure what you're doing.)
Date: 15 Nov 2009 15:48:41
Message: <4b006929@news.povray.org>
Awesome! I wasn't aware of the vtransform function. Thanks!
Mike
Date: 15 Nov 2009 23:23:52
Message: <4b00d3d8@news.povray.org>
Is there an easy way to combine multiple transformations? I tried each
of the following:
#local trans_c = transform
	transform {trans_a}
	transform {trans_b}
	trans_a + trans_c
#local trans_c = trans_a + trans_b
Mike
Date: 15 Nov 2009 23:26:35
Message: <4b00d47b$1@news.povray.org>
> of the following:
> Mike
Nevermind. There was a typo in my working code. The first example works.
Mike
