POV-Ray : Newsgroups : povray.advanced-users : Strange pigment error (3.6.1) Server Time
9 Jun 2026 08:02:15 EDT (-0400)
  Strange pigment error (3.6.1) (Message 11 to 12 of 12)
Subject: Re: Strange pigment error (3.6.1)
Date: 11 Sep 2009 19:26:54
Message: <4aaadcbe$1@news.povray.org>
SharkD wrote:
> clipka wrote:
>> SharkD schrieb:
>>> As I pointed out in my second post, the error only occurs after I
>>> apply the turbulence warp.
>> Probably because the object normally doesn't touch the "dangerous"
>> range, but the warp pertubs the coordinates in such a way that the
>> pattern's original y<=-1 range ends up "exposed".
> Is it possible to do use an IF statement to substitute a different
> function where y<=-1?
> -Mike
Changing the second function to this seems to fix it:
#local Temp_fnc3 = function
   max(0,min(1,Temp_fnc1(x,log(max(y + 1,0.000000000001))/log(2),z)))
Date: 11 Sep 2009 21:42:09
Message: <4aaafc71$1@news.povray.org>
SharkD wrote:
> SharkD wrote:
>> I'm using the following pigment:
>> #local Temp_fnc1 = function {pigment {spherical}}
>>     Temp_fnc1(x, log(y + 1) / log(2),z).gray
>> The image actually *renders* most of the way. But about 3/4 done it
>> quits with the error, "Parse Error: Floating-point exception detected
>> in function 'Temp_fnc3'. Your function either attempted a division by
>> zero, used a function outside its domain or called an internal
>> function with invalid parameters."
>> Aren't parse errors supposed to occur *before* the image begins
>> rendering? How do I fix it?
>> -Mike
> Oops! I made a mistake when copying the function. Here's the actual code:
>     1 - min(1, sqrt(x*x + y*y + z*z))
>     max(0,min(1,Temp_fnc1(x, log(y + 1) / log(2),z)))
> And the warp:
> warp
>     turbulence    <1/4,1/64,1/4,>
>     octaves        4
>     lambda        2
>     omega        1/2
The above function transforms the sphere such that it is expanded
logarithmically along the y axis. What I would like to do next is to
expand it based on its distance from the origin instead. Any ideas?
-Mike
