Is there a way to generate a heightfield from a pigment? The heightfield
object requires an actual image AFAIK.
Thanks!
-Mike
Absolutely
You can turn your pigment into a function
#declare myPigFn =
function {
pigment { my_pigment ]
and pass it directly to the height field as a function
height_field {
function HF_Res_X, HF_Res_Z { myPigFn(x,y,z).red * vScale }
water_level n.n
".red" specifies that the height data follows the intensity of the red
channel. Alternatively you may use the blue or green channels or any of
the direction vectors (x,y,z)
Numerical functions can also be used, but do not require the vector
component.
remember that height_fields occupy a unit cube from 0,0,0 to 1,1,1.
A.D.B.
> Thanks!
> -Mike
Anthony D. Baye wrote:
> Absolutely
> #declare myPigFn =
> function {
> height_field {
> water_level n.n
> component.
> Regards,
> A.D.B.
I get the error:
"Parse Error: Expected 'numeric expression', undeclared identifier
'HF_Res_X' found instead"
-Mike
HF_Res_X and HF_Res_Y are place holders for variable values.
replace them with a resolution
eg. 256, 256 or 512, 512
A.D.B.
>> Absolutely
>> #declare myPigFn =
>> function {
>> height_field {
>> water_level n.n
>> of the direction vectors (x,y,z)
>> component.
>> Regards,
>> A.D.B.
> I get the error:
> -Mike
Just for info: This actually causes POV-Ray to internally sample a
bitmap of the specified resolution from the function.
Resolution of what? *What* are the numbers measuring, exactly?
-Mike
The resolution of the height field!! Think of the resolution as a count of
square subdivisions.
The height field is still 1 unit by 1 unit, but that one-square-unit area is
divided into X*Z square subdivisions. It's no different than using a 512x512
pixel image as your source.
A.D.B.
> -Mike
