POV-Ray : Newsgroups : povray.advanced-users : bounding turbulence Server Time
9 Jun 2026 08:02:00 EDT (-0400)
  bounding turbulence (Message 11 to 13 of 13)
Subject: Re: bounding turbulence
Date: 31 Jan 2010 22:48:02
Message: <4B664EA6.6090508@joplin.com>
Thank all for you input.
  Aline and Slime formulas where a good starting points.
The formula I came up with is
  Scale=1/(1+Turbulence*.5+sqrt(3)*Turbulence*Omega*Octaves/10)
Where
  0<= Turbulence  <=1
  0<= Octaves <=10
  0<= Omega  <=1
As Slime pointed out lambda has little effect on Scale.
Note that if Turbulence=0 there is no turbulence
and if Omega=0 Octaves has no effect but Turbulence>0 does.
If Octaves=<2 Omega has no effect but Turbulence>0 does.
Tanks again!
Have Fun!
Date: 31 Jan 2010 22:58:10
Message: <4B665106.8030206@joplin.com>
I thought about using eval_pigment but I wanted a formula not a
procedure. Also when turbulence and octave are high there
are tiny islands of color so a search would have to be very fine.
How fine would be just be a guess.
Date: 1 Feb 2010 17:40:00
Message: <web.4b6757455bb1469f65f302820@news.povray.org>
Leroy Whetstone <lrw### [at] joplincom> wrote:
> ...Also when turbulence and octave are high there
That's true, especially with a high omega value. (In my own turbulence
use--particularly when working with an image_map--I'm usually willing to let a
little of the 'outer bits' of color spill off the object, if it's not too
noticeable.)
Ken
