Hi all,
I have a scene that would take some 280 hours to render with
radiosity/antialiasing, so I'd like to find a way of splitting it into smaller
segments and rendering each segment separately. Is there a way to do it?
- If I just render each segment, I get severe banding.
- If I turn off antialiasing, save a radiosity file, and load the file for use
with antialiasing, I get very poor results. (I thought this would work better.)
- I assume that httpov won't help, right?
Any suggestions?
Thanks.
Subject: Re: radiosity and distributed rendering?
Date: 20 Feb 2008 10:34:32
Message: <47bc0238$1@news.povray.org>
I use this technique often, and I get good results with 3.6 (see for
example my kitchen scene: it was rendered across several computers).
I suppose you are not using the beta for this... so, perhaps the problem
is with the load_file settings: remember you have to use the same settings
for error_bound, nearest_count and recursion_limit, not just load_file.
Hope this helps...
Jaime
JH nous apporta ses lumieres en ce 2008/02/19 09:26:
> Hi all,
> Any suggestions?
> Thanks.
When using save_file/load_file, you must keep all radiosity settings unchanged
exept:
In the final pass use: pretrace_start 1 pretrace_end 1 always_sample 0
All other settings MUST remain the same.
You know you've been raytracing too long when you've gained twenty pounds
sitting at the computer, but can't tell because your beard covers your stomach.
Taps a.k.a. Tapio Vocadlo
JH schrieb:
> Hi all,
Since it has been mentioned that certain settings have to be kept the
same when separating pretrace and render - this is not the case for
most. In fact i think only recursion_limit must not be modified when
reusing radiosity data.
In some cases it is a good idea to selectively change certain settings
to avoid discontinuities between separately rendered tiles.
always_sample is the obvious and documented one.
The general approach to avoid radiosity sampling in the final pass is to
take a lot of samples in the pretrace (by using low error_bound, maybe
high nearest_count and possibly adapting minimum_reuse). pretrace_end
has to be sufficiently low to actually take all those samples of course
(and the pretrace render resolution has to be sufficient for that of
course). In the final renders you need to adapt all those settings to
mostly avoid further samples (to completely avoid them is hardly
possible though).
-- Christoph
