POV-Ray : Newsgroups : povray.advanced-users : Bizzare space mapping problem Server Time
9 Jun 2026 05:56:52 EDT (-0400)
  Bizzare space mapping problem (Message 11 to 13 of 13)
Subject: Re: Bizzare space mapping problem
Date: 8 Sep 2007 06:22:09
Message: <46E278CF.6000507@hotmail.com>
Orchid XP v3 wrote:
> Warp wrote:
>>   Can you describe, even at a conceptual level, how you could map a 2D
>> pattern onto a 3D shape with no stretching whatsoever?
> I've spent about 20 minutes attempting to bend my mind around such a
> concept... Apparently my mind is insufficiently bendy.
> I know it's impossible to map *a sphere* onto a flat grid without
> distortion, but I'm uncertain as to whether there exists *any* 3D
> surface can be mapped to a 2D one without disturtion.
- simple one: a cylinder.
- any infinite continuous surface that extends linear in one direction
(of which the cylinder and the plane are special cases)
- a finite object where for every point there is a straight line that
extends over the whole object (a cone is such an object, another is the
side of http://ec1.images-amazon.com/images/I/2181V1N9QCL._AA170_.jpg )
Date: 11 Sep 2007 06:40:59
Message: <46e670bb@news.povray.org>
> I'm attempting to solve a problem so fiddly that it's really quite hard to
> explain what I'm even trying to *do*!
> Basically, I want to make a 2D pattern with seemless repeats out of a
> normal POV-Ray 3D pattern. However, I can't seem to find a way to take a
> flat 2D grid and bend it into some kind of 3D form in such a way that the
> pattern has a uniform frequency everywhere.
A good trick I know from realtime 3D graphics is as follows:
Define 3 patterns for the X Y and Z planes.  At each point on the surface
you are rendering, take a weighted average of the 3 patterns based on the
magnitude of the normal vector in that direction.  So if your surface normal
is <1,0,0> or <-1,0,0> you would take 100% from pattern X, and none from the
others.  etc
This way you get a nice smooth blending that covers the entire shape nicely
and you don't get any areas where the pattern looks horribly stretched.
It works very well for organic shaped things (eg rocks, animals) with
organic-type textures (wood/grass/granite).
Not sure how you would implement this in POV, but given the flexibility of
POV I'm sure someone could implement it (I think you need megaPOV to use the
normal data in a pattern).
Date: 11 Sep 2007 07:43:44
Message: <46e67f70@news.povray.org>
scott nous apporta ses lumieres en ce 2007/09/11 06:40:
>> hard to explain what I'm even trying to *do*!
>> a flat 2D grid and bend it into some kind of 3D form in such a way
>> that the pattern has a uniform frequency everywhere.
> surface you are rendering, take a weighted average of the 3 patterns
> based on the magnitude of the normal vector in that direction.  So if
> your surface normal is <1,0,0> or <-1,0,0> you would take 100% from
> pattern X, and none from the others.  etc
> nicely and you don't get any areas where the pattern looks horribly
> stretched.
> of POV I'm sure someone could implement it (I think you need megaPOV to
> use the normal data in a pattern).
There is the slope pattern that can take any arbitrary refference vector. That
combined with the average pattern could be used to do something similar.
You know you've been raytracing too long when you are compulsive, neurotic,
anti-social, paranoid and manic-depressive but basically happy.
Quietly Watching
