POV-Ray : Newsgroups : povray.advanced-users : trace + color? Server Time
10 Jan 2025 17:06:37 EST (-0500)
  trace + color? (Message 1 to 5 of 5)
Subject: trace + color?
Date: 28 Jun 2007 11:05:57
Message: <4683ce55$1@news.povray.org>
   just a quick question... i haven't povrayed in a Very long while!
I'm still thinking about my project and I would need to use povray to extract
shape information from an object (easy with trace, get the position of a surface
and its normal), but I'm wondering about the color at that point.
Right now, i was thinking on having an orthogonal camera make a zoomed-in render
of that point, while the camera would be sitting along the normal axis.
But, is there a better way to get the color, to finally right it to stdout like
i do with trace?
Thanks,
   Simon
Subject: Re: trace + color?
Date: 28 Jun 2007 11:35:38
Message: <TaEHZEAuT9gGFwRE@econym.demon.co.uk>
Wasn't it Simon who wrote:
>Hi,
>i do with trace?
Once you've got the point you can get the pigment with eval_pigment
(except for things like slope pattern pigments). I don't think that
there's anything that will return you the final pixel colour after
things like lighting, shadows, reflection, refraction and radiosity have
been applied.
Mike Williams
Gentleman of Leisure
Date: 28 Jun 2007 12:13:53
Message: <4683de41$1@news.povray.org>
> been applied.
Excellent, that is exactly what i need... to get the raw color of the point,
independent from scene.
Many thanks for quick reply!
   Simon
Date: 28 Jun 2007 13:40:01
Message: <web.4683f14a7de6b226e94cc5130@news.povray.org>
> >Hi,
> >i do with trace?
> been applied.
> Mike Williams
Hmm, this has me thinking, based on something I'm working on... I wonder
what the best way to do it would be if you are sampling arbitrary points in
a union of many objects with various pigments where knowing the pigment used
and the orientation of each object within the union might not be straight
forward....  I can think of a couple of ways but they aren't very
efficient.  E.g. creating slices like LikeNoOther is doing, using an ortho
camera and then sampling the resulting image.
Charles
Date: 2 Jul 2007 16:46:23
Message: <4689641f$1@news.povray.org>
> Charles
Hi Charles,
   I'll tell you a bit about my own project...
There is an object which is very complex, say, a space ship!  I will place the
ship inside a box {-1,1}, by scaling it and moving it in the cube.  Optionnally
I may have to scale it further to have the center of the ship lie on the origin
<0,0,0> to help the next stage of my project.
Then I will trace from the 3 axis at a specified interval. Probably missing
important data.  And then, I will compare two readings that are side-by-side,
and check the difference.  If the difference is higher than a specified
threshold, then I have to "sub-divide" and resample that region at a smaller
interval.  And this infinitly until the differences are under the threshold
values or until subdivision has reached a certain level (ie, a checker would be
sub-divided infinitly to have a sharp black to white line, instead of a small
gradient between the two).
The specified values will definately depend on the complexity of the object
(like if the space ship has tiny antenas...).
This results in a massive amount of information which is then compiled and
optimized into another format for use in later stages of the project.  The
process is pretty much brute, but it should do what I need and I prefer to
concentrate my efforts on the rest of the project.
Oh, one more thing, i only scan one object at a time, ie: The car body, a tire,
every moving parts separately, to assemble them in the later stages of my project.
HTH,
   Simon
