POV-Ray : Newsgroups : povray.advanced-users : Random points on surface of an object Server Time
17 May 2026 04:28:48 EDT (-0400)
  Random points on surface of an object (Message 1 to 9 of 9)
Subject: Random points on surface of an object
Date: 22 Jan 2007 16:38:53
Message: <45b52eed$1@news.povray.org>
This morning I woke up with a solution
to placing a random distribution of points
onto arbitrary objects. I'm not sure if any
of you have ever had one of these dreaming
moments of inspiration, but I figured it was
worth sharing it. I think someone had asked
about something like this, but I've lost the
thread.
Basically, you just check that the distance
from a random point in the bounding to
a trace hit on the object is shorter than
some threshold distance. That way the
random distribution approaches that of
the surface.
Here's a sample scene, with the macro.
#macro RandOnSurface(Obj, rsd, thresh)
   #local mn = min_extent(Obj);
   #local mx = max_extent(Obj);
   #local dist = 1000000;
   #while (dist>thresh)
      #local flag = 0;
      #while (flag = 0)
         #local rfrom = VRand_In_Box(mn, mx, rsd);
         #local rdir = vrotate(<1,0,0>,
            <360*rand(rsd),360*rand(rsd),360*rand(rsd)>);
         #declare Norm = <0, 0, 0>;
         #local hit = trace(Obj, rfrom, rdir, Norm);
         #if (vlength(Norm) != 0)
            #local flag = 1;
      #local dist = vlength( hit - rfrom);
   #local result = hit;
   (result)
#declare Bent = merge {
   cylinder{<0,-1,0>,<-1,0,0>,0.2}
   cylinder{<-1,0,0>,<1,0,0>,0.2}
   cylinder{<1,0,0>,<0,1,0>,0.2}
   sphere {<-1,0,0>,0.2}
   sphere {<1,0,0>,0.2}
object {Bent pigment {Blue transmit 0.7} }
#declare rsd = seed(1);
#local c = 0;
#while (c<1000)
   #local p = RandOnSurface(Bent, rsd, 0.05);
   cone{<0,0,0>,0.025,<0,0.1,0>,0
     Point_At_Trans(Norm)
     translate p
     pigment{Red}
   #local c = c + 1;
Subject: Re: Random points on surface of an object
Date: 22 Jan 2007 17:34:13
Message: <45b53be5$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote in message
news:45b52eed$1@news.povray.org...
> ...  I think someone had asked
> thread. ...
Hi Tim,
I think that would be the thread entitled 'trace function question' in
povray.newusers.
Chris B.
Date: 22 Jan 2007 18:59:34
Message: <45b54fe6$1@news.povray.org>
> the surface.
brute force but should be a reasonable approximation if you
are willing to wait a bit for all those missing rolls.
Although I think you should also pick a uniform distribution
of trace directions, otherwise you will have some unnecessary
systematic error. But this can be fixed by
http://mathworld.wolfram.com/SpherePointPicking.html
Also, the bounding box should be extended by "threshold",
else areas at the border only have 50% chance of hitting.
Date: 22 Jan 2007 22:31:34
Message: <45b58196$1@news.povray.org>
I didn't rotate 360 y and 180 relative as in polar notation,
which is what causes that common error pointed out on wolfram,
but by 360 on 3 fixed axes. The result should be uniform already?
I guess you could use Ingo's VRand_On_Sphere() from rand.inc
#local rdir = VRand_On_Sphere(rsd);
Oops, yep.
   #local mn = min_extent(Obj)-thresh;
   #local mx = max_extent(Obj)+thresh;
Date: 28 Jan 2007 18:30:01
Message: <web.45bd314015df458d8a6768e40@news.povray.org>
Amazing! Thanks for sharing this.
Date: 31 Jan 2007 04:03:37
Message: <45c05b69@news.povray.org>
Brilliant!!! Very useful!
Thank you very much indeed!
Date: 19 Feb 2007 07:30:29
Message: <45d99865$1@news.povray.org>
Tim,
I have been playing with your macro and I have the following question, as I
am at a loss about how to solve it myself (see the image in p.b.i.).
I scaled here the cones to a flat shape. What I would like is to always have
the eliptic bases oriented horizontally, whatever their location, not like
in the image, where part of them are oriented vertically. How could that be
achieved with your macro? I experimented a bit and read the docs, but I am
at a loss.
Thanks a lot!
Date: 20 Feb 2007 03:46:11
Message: <45dab553$1@news.povray.org>
> I am at a loss about how to solve it myself (see the image in p.b.i.).
> have the eliptic bases oriented horizontally, whatever their location, not
> like in the image, where part of them are oriented vertically. How could
> that be achieved with your macro? I experimented a bit and read the docs,
> but I am at a loss.
Trace and the RandOnSurface macro only return a point and a normal.
You could ignore the vertical portion of the normal and force some
object to be horizontal in respect to the horizon.
Point_At_Trans(vnormalize(<Norm.x,0,Norm.z>))
but you would need to decide what to do if the normal is vertical
or it might error out.
However, I think what you intend is to follow the shape of the object?
A normal isn't enough to generate info about how the surface
shape slopes nearby to some random point. You could trace nearby
points and rotate based on that perhaps.
Date: 20 Feb 2007 07:57:57
Message: <45daf055$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> schreef in bericht
news:45dab553$1@news.povray.org...
Exactly.
This works as I want it to do!! I shall think about something for those
cases where Norm.y is vertical (probably just skip it).
Thank you!! A simple solution indeed.
Not necessarily for my purpose. I want to experiment with a given shape on
which "leaves" are growing. Basically, the leaves are all oriented
horizontally and bending slightly down.
