POV-Ray : Newsgroups : povray.advanced-users : Isosurface speed Server Time
9 Jun 2026 02:25:17 EDT (-0400)
  Isosurface speed (Message 17 to 20 of 20)
Subject: Re: Ooo... a solution?
Date: 28 Sep 2006 09:19:51
Message: <pan.2006.09.28.13.20.12.48220@knobbits.org>
On Wed, 27 Sep 2006 20:44:05 +0100, Orchid XP v3 wrote:
> My particular function was something like x^18 + ... = 0. It has almost
> vertical sides, yet the "interesting" part has a tiny derivative. My
> using the log() function I can "magnify" the interesting bit, and zoom
> out the unimportant vertical walls that are confusing the poor root solver.
> However, note that you must make sure the function is NEVER NEGATIVE,
> since log(-1) is a complex number, and POV-Ray won't like that. This
> sometimes requires you to translate the function in the Y-direction,
> take the log, and then translate the result back again:
>    f2(x) = k + log(f1(x) - k)
> Selecting the correct k turns out to be very critical. The log function
> shrinks large features, but it can also "magnify" small ones. If you get
> the "wrong" value for k, you can end up creating big vertical side RIGHT
> NEXT TO THE ZEROS. That means you MUST use a high max_gradiant or
> POV-Ray will overshoot the zeros - the exact thing we were trying to
> avoid...
Yeah, the magnification of small values (which also applies to, say,
sqrt(x)), is something I forgot about.  I guess real world functions would
be less trivial to "map" in the sense I was talking about.
> (The problem gets even more fun if you start taking double-logs!)
Why would you want to do that for a function other than a
double-exponential?  Masochism? Maths fetish? :)
>> I'm curious, could this kind of thing theoretically be done
>> automatically by povray?  What if it were to use log(function) or
>> sqrt(function) or 1/function to find the surface points rather than the
>> actual function, and the max_gradient were to apply to that function
>> instead of the original?
> For every function for which this is faster, there is another one for
> which it is slower. It would probably take more time to detect which
> case applies than to just use the "wrong" variant. (See above.)
> OTOH, it might be worth making a *keyword* to do this kind of
> optimisation automatically instead of altering the function by hand...
Also, I just realised, I think most functions with ever-increasing
gradients could be reined in by putting it in a min() or max() function,
or both.  Would that work with your exp function?
Mick.
Remove the -news from my email address.
http://mickworld.knobbits.org/
Date: 28 Sep 2006 20:34:47
Message: <451c6a27$1@news.povray.org>
Michael (Micksa) Slade nous apporta ses lumieres en ce 28/09/2006 09:20:
>> avoid...
> Mick.
You can come acros functions that have even more extreem gradients and a single
log still give you a max_gradient in the thousands, like a 20th degree or more
or an x^10x kind of case. You then may want to use double logs. In that case, it
can be usefull to use log(max(0, log(YourFunction))) to clip negative values.
If That Phone Was Up Your Butt, Maybe You Could Drive A Little Better!
Date: 29 Sep 2006 00:30:00
Message: <web.451ca0b3b14bbacda2fccf710@news.povray.org>
I suppose you could try using the evaluate keyword instead of just giving
max_gradient...  go with evaluate 1e+17,3,0.1 or so, and maybe it'd run at
a decent speed (if you're lucky) without mucking about with renormalizing
the function.
Date: 29 Sep 2006 15:00:23
Message: <451d6d47$1@news.povray.org>
> the function.
The evaluate keyword is only for figuring out what max_gradient should
be optimally set to. It doesn't change the need to make the function
*reasonably* well behaved to get good performance...
