POV-Ray : Newsgroups : povray.advanced-users : Pause Server Time
17 May 2026 05:44:13 EDT (-0400)
  Pause (Message 1 to 10 of 15)
Subject: Pause
Date: 29 Apr 2006 08:04:47
Message: <4453565f@news.povray.org>
Is there a way to "pause" POV-Ray under UNIX?
Subject: Re: Pause
Date: 29 Apr 2006 08:25:46
Message: <44535b4a@news.povray.org>
None that I know of (but I don't know everything :) )
Ger
Subject: Re: Pause
Date: 29 Apr 2006 10:12:19
Message: <44537442@news.povray.org>
  Not in POV-Ray itself, but you can suspend (almost) any program in unix
by pressing ctrl-z on the console where you started it (this actually sends
SIGHUP to the process, which can also be sent to it by other means, eg.
using the kill command). You can then continue it by writing 'fg' in the
same console.
Subject: Re: Pause
Date: 29 Apr 2006 12:10:31
Message: <44538ff7$1@news.povray.org>
> same console.
Right, cool.
I'm running it remotely using SSH. I start POV-Ray, then log out of SSH.
I don't know of a way of reconnecting to the original console. So I can
use the kill command to pause it, but how can I unpause it? Is there
some signal for that, or...?
Subject: Re: Pause
Date: 29 Apr 2006 14:42:35
Message: <4453b39b@news.povray.org>
Yep, there is a signal for that, "CONT". You can use the "kill" command
to send it to your POV process (Despite its name, "kill" can send any
signal to a process). You need the process id (PID) of the POV process
to do that, which you can get from ps:
	ps -A | grep povray
The first number in the line shown is the PID. Use it with kill:
	kill -s CONT your_pid_here
You may need to grep for something else instead of "povray" if you're
using MegaPOV.
HTH,
Florian
Subject: Re: Pause
Date: 29 Apr 2006 15:11:15
Message: <4453ba53$1@news.povray.org>
>> SSH. I don't know of a way of reconnecting to the original console. So
>> I can use the kill command to pause it, but how can I unpause it? Is
>> there some signal for that, or...?
OK, thanks.
> (Despite its name, "kill" can send any signal to a process).
Yes... another bit of UNIX randomness.
As far as I know, kill merely *defaults* to sending SIG_KILL...
Subject: Re: Pause
Date: 29 Apr 2006 15:31:21
Message: <4453bf06@news.povray.org>
  No, it defaults to sending SIGTERM.
  SIGKILL should basically never be used because it's "too strong", only
when no other options work.
  (OTOH there exist situations where even SIGKILL won't kill a process,
but that's another story.)
Subject: Re: Pause
Date: 29 Apr 2006 15:42:35
Message: <4453c1a4@news.povray.org>
  Actually what you want to use here is an utility called 'screen'.
'screen' is a terminal emulator which keeps running in the background
independently of the terminal process which started it. It can be used
to keep programs running in the background even if you close terminals
or log out of the system.
  It works like this:
  The first time you want to use 'screen', log in the system and just
write 'screen' (it will give you some info and ask you to press enter).
  Now you are in the 'screen' terminal emulation. You'll not notice any
difference (except that ctrl-a is captured by screen).
  Now start povray (or whichever program you want).
  Now, while povray is running, press ctrl-a ctrl-d. This will "detach"
the current screen. This means that you "exit" screen to the console
where you started it in the first place, but screen (and povray, which
you started inside it) will keep running in the background.
  Now you can log out and povray will still be running.
  When you want to open screen again, log in and write "screen -r" (r as in
reattach) and voila, the console where you started povray from pops up.
  You can actually open several virtual consoles from screen. This is done
by pressing ctrl-a ctrl-c. To change between the last two consoles press
ctrl-a ctrl-a. You can also jump to a specific console with ctrl-a <number>.
To close a console simply write "exit" there (you can also kill a console
with ctrl-a ctrl-k, but that violently kills all the processes running in
that console so be careful).
  If you write "exit" in the only virtual console, it will terminate screen
altogether.
  Screen is especially useful when connecting to a remote machine with ssh
because it makes things safer. Your connection may suddenly be cut, but
that doesn't matter: After you log in again, you can get back to where
you were with "screen -d -r" (in this case the -d makes the running screen
to remotely deattach first; this is necessary because it was not explicitly
deattached when the connection suddenly dropped).
Subject: Re: Pause
Date: 29 Apr 2006 19:00:02
Message: <4453eff2$1@news.povray.org>
Thanks for the info. I'll give that a go.
Subject: Re: Pause
Date: 29 Apr 2006 19:01:16
Message: <4453f03c$1@news.povray.org>
Ah yes, you're right. (Actually, you do that a lot... must be skill or
something.)
Isn't that the one the kernel sends during shutdown?
