POV-Ray : Newsgroups : povray.advanced-users : Media speed Server Time
28 Sep 2024 18:11:06 EDT (-0400)
  Media speed (Message 1 to 6 of 6)
Subject: Media speed
Date: 14 Apr 2006 16:54:39
Message: <44400c0f$1@news.povray.org>
Perhaps I'm not understanding the media sampling parameters quite right,
but here goes...
I have a block like this:
interior
   media
     scattering {1, 1}
     density {Fn6(x, y, z)}
This is supposed to be the clouds for my sky (which takes up about 50%
of the image with the current camera angle). It renders at about 3,000
pixels/second.
Now, if I add "intervals 10" (or indeed, any other setting) the render
slows down to 1,800 pixels/second. And yet, the documentation claims
that 10 is the default value... Does POV-Ray do something special if no
explicit value is given or something? (The images produced are markedly
different as well by the way.)
Subject: Re: Media speed
Date: 14 Apr 2006 17:00:46
Message: <44400d7d@news.povray.org>
  The documentation is old. It's the default value when using method 1, but
since the default method was changed to 3 those other defaults changed too,
but nobody remembered to update the documentation.
  I have seen the defaults for method 3 but I don't remember them. It might
have been 1 for intervals.
Date: 14 Apr 2006 17:13:36
Message: <44401080@news.povray.org>
Ah yes - isn't method 3 the adaptive subdivide one? Would make sense to
have a single interval for that...
Just tried rendering with intervals=1, and it does indeed produce the
same results as with no specification. (Same speed also.) Any idea what
the default samples setting is? (If not, I'll play tomorrow and see if I
can find it. It'll be a lowish number...)
Damn... somebody needs to update the docs! LOL. (Ah, but that would
require a *person*. And not just any person - but a person who has the
necessary information to do it. And the time... I imagine nobody is even
going to look at such a thing until the current beta goes release.)
Date: 14 Apr 2006 22:22:55
Message: <444058ff$1@news.povray.org>
Orchid XP v2 nous apporta ses lumieres en ce 14/04/2006 17:13:
>> 1, but
>> too,
>> might
intervals =1, no need to change it. Using a to large value can cause artefacts.
samples =3, minimum value, can be set higher as needed.
You don't need to use a spread of values like samples 10,100, just use a single value.
You are always doing something marginal when the boss drops by your desk.
Date: 15 Apr 2006 03:56:18
Message: <4440a722$1@news.povray.org>
> artefacts.
> single value.
Thanks.
Date: 15 Apr 2006 04:25:07
Message: <4440ade3$1@news.povray.org>
> artefacts.
> single value.
For reasons I don't really understand, if I don't specify the number of
intervals, no other settings seem to have any effect at all. However, if
I set intervals=2, now changing samples has an effect. (And yes, low
intervals and high samples does look a lot better - and renders faster too.)
