POV-Ray : Newsgroups : povray.advanced-users : What... the hell...? Server Time
19 Dec 2025 08:03:27 EST (-0500)
  What... the hell...? (Message 1 to 9 of 9)
Subject: What... the hell...?
Date: 11 Mar 2006 16:03:07
Message: <44133b0b$1@news.povray.org>
3.2.1.3.4  Functions
"atan2(A,B): Arc-tangent of (A/B). Returns the angle, measured in
radians, whose tangent is (A/B). Returns appropriate value even if B is
zero. Use atan2(A,1) to compute usual atan(A) function."
Um... yeah, OK... so why does atan2(0, 0) give we a fatal parse error?
(POV-Ray v3.6, Windows.)
Subject: Re: What... the hell...?
Date: 11 Mar 2006 17:04:00
Message: <44134950@news.povray.org>
Orchid XP v2 wrote:
> 3.2.1.3.4  Functions
The arguments to atan2 are the rise (A) and run (B) of a tangent line for
which you want to know the angle.  If the line runs (B != 0) but does not
rise (A = 0), you have a horizontal line.  If the line rises (A != 0) but
does not run (B = 0), you have a vertical line.  But if the line does not
rise (A = 0) or run (B = 0), what do you have?  The line does not go
anywhere, so the angle is undefined.
I haven't looked at the pov code, but I expect this is the reason for the
parse error - there's no correct way to evaluate the expression.
Ken
Date: 11 Mar 2006 17:06:53
Message: <441349fd$1@news.povray.org>
The angle is definitely undefined - but I would be quite happy for POV
to return *any* angle to me... Now I have to figure out how to get round
this parse error. :-/
(The number that results is being fed into a rotate statement, so in the
case of both numbers being zero, whatever rotation ends up happening
won't make any difference to the final image...)
Date: 11 Mar 2006 18:47:24
Message: <4413618c$1@news.povray.org>
#declare A = ...;
#declare B = ...;
#if (A != 0 | B != 0)
#declare angle = atan2(A,B);
#else
#declare angle = 0;
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Mar 2006 22:44:39
Message: <441e2527@news.povray.org>
  Because the result is not defined. You are basically asking the
direction of a zero vector, which has none.
Date: 20 Mar 2006 07:31:55
Message: <441ea0bb@news.povray.org>
I just thought the whole point of using atan2 was to _avoid_ divide by
zero errors.
Sure, if the vector has a length of zero it has no defined direction.
OTOH, I would imagine in most cases it just wouldn't *matter* what
number the function returns in this case - just so long as it returns
something, rather than an error...
Oh well.
Date: 20 Mar 2006 08:06:10
Message: <441ea8c2$1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:441ea0bb@news.povray.org...
> zero errors.
> OTOH, I would imagine in most cases it just wouldn't *matter* what number
> the function returns in this case - just so long as it returns something,
> Oh well.
The easy workaround would be to put Slime's solution into your own macro
e.g. Orchidatan2(A,B) returning the angle.
Then, if you've got a lot of atan2 calls you can just do a global replace.
Regard,
Chris B.
Date: 26 May 2006 18:40:00
Message: <web.447782ae7e4925a01009749b0@news.povray.org>
> zero errors.
> Oh well.
Yes, but not when A and B are BOTH zero.  Then the function is undefined.
You could simply do some error checking before trying to calculate the
function, and skip it altogether when A = B = 0.
Mike
Date: 11 Jun 2007 11:14:34
Message: <466d66da$1@news.povray.org>
> zero errors.
> Oh well.
