POV-Ray : Newsgroups : povray.advanced-users : Internal reflactions Server Time
17 May 2026 07:17:21 EDT (-0400)
  Internal reflactions (Message 1 to 4 of 4)
Subject: Internal reflactions
Date: 26 Jan 2006 16:33:21
Message: <43d94021@news.povray.org>
Does POV-Ray properly render internal reflactions?  I can't seem to get it
to.  I'm trying to set up a light pipe that should be near TIR (total
internal reflaction).  What I've tried so far is to wrap the pipe with a
mirror, but that isn't quite the correct to do this.
Ideally, the surface smoothness would affect the internal reflections so I
could correctly model what happens on a scuffed or scratched surface.
Subject: Re: Internal reflactions
Date: 26 Jan 2006 19:27:51
Message: <43d96907$1@news.povray.org>
LEDpipe nous apporta ses lumieres en ce 26/01/2006 16:33:
It does do total internal reflection realisticaly, but... for the light from a
light_source to do
it, it must emit photons.
You need to add a protons block in the #global_settings{}
You also need to add a photons block to your object. That one will look like:
photons{target refraction on}
You can also add "reflection on" but probably don't need it.
In your case, you probably also need to increase the max_trace_level, possibly to it's
maximum value
of 255.
Read section 3.6.3  Photons in the documentations.
Just because someone doesn't love you the way you
want them to, doesn't mean they don't love you with
all they have.
Date: 27 Jan 2006 13:02:16
Message: <43da6028$1@news.povray.org>
Thanks.  I had been using photons.  I think my pipe just needs more work ...
> from a light_source to do it, it must emit photons.
> like:
> possibly to it's maximum value of 255.
> Alain
Date: 14 Jul 2007 17:35:02
Message: <web.469940b32278acb5873186e0@news.povray.org>
I've been trying to model a light-pipe also, and I've gotten internal
reflection to work, but only if I turn conserve_energy off. If it's
enabled, I get no visible internal reflection at all. My photons are all
emitted in a very narrow beam (spotlight of 0.04 degrees divergence), which
requires an extremely small photon-spacing on the glass pipe target, but it
doesn't seem to make any difference how small the spacing is unless
conserve_energy is off (i.e. you get no visible effect from photons, even
with no other lighting in the scene).
My light pipe and light source are configured such that I should be getting
total internal reflection. So perhaps conservation of energy isn't
important in this case, assuming that 100% of the incoming light gets
reflected (internally). But I wanted to look at step-index light pipes, so
ideally there would be partial reflection at the interface between two
slightly different indices of refraction. I think this will probably
require that conserve_energy is enabled for realistic behavior to be seen.
Dave
