POV-Ray : Newsgroups : povray.advanced-users : Photon trickery Server Time
11 Jan 2025 01:43:30 EST (-0500)
  Photon trickery (Message 1 to 4 of 4)
Subject: Photon trickery
Date: 29 Oct 2005 17:07:31
Message: <4363e493$1@news.povray.org>
I've got a scene with a large body of water where I want to use some photons
for a small area in the foreground. My problem is that I can't hide the
transition between the area that has photons and the area that doesnt.
The problem is: the photons get bent by the refraction and the conventional
light obviously doesn't. Which creates a shadow artefact on one side, and a
double-lit area on the other.
Now, I can think of a couple of ways this could be fixed, but they're both
impossible in povray!
Option 1: gradually adjust the refractive index within the photon area, so
that it matches the non-photon area at the sides, use this to save photons
then switch it off in the main render. But as far as I know pov doesn't let
you gradually adjust the refraction. Or does it?
Option 2: Adjust the photon spacing so that we have a lot of densly packed
photons (using a smaller gather radius) in the foreground area but really
low-quality photons in the distance. This will give really nice lighting and
be more accurate than what I've got now.
For the time being, I'll just use photons on a much larger area so the
transition's far enough away to not see it. But I'm using literally 10x as
many photons as I need for the effect I want.
Anyway, I'm just posting this here to see if anyone who knows more about
pov's photons than me can tell me if either of those options are possible,
or if there's any other trick.
Thanks in advance for any help
Tek
http://evilsuperbrain.com
Subject: Re: Photon trickery
Date: 29 Oct 2005 19:16:27
Message: <436402cb$1@news.povray.org>
Tek nous apporta ses lumieres en ce 2005-10-29 17:07:
Not possible. You can flaten the relief/normal as you go farther away to acheive a
similar effect.
Maybe what you need: use photons in the near part and caustics farther away. Maybe
using a
light_group for the farther part to fill up any ramaining gap.
The part that receive the caustics may be lowered a little to hide a dark band. May
not be possible,
or very dificult to properly do.
The transition won't be perfect, but the refraction of the vewing rays can make that
hard to
distinguish. Some judiciously projected shadows can also somewhat hide the transition.
With your option 2, close by area: high quality photons, middle range with low quality
photons, far
area use caustics.
REMEMBER: WHATEVER HAPPENS, HAPPENS FOR A REASON.
Date: 29 Oct 2005 20:41:07
Message: <436416a3@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:436402cb$1@news.povray.org...
> away. Maybe using a light_group for the farther part to fill up any
> ramaining gap.
> band. May not be possible, or very dificult to properly do.
> make that hard to distinguish. Some judiciously projected shadows can also
> low quality photons, far area use caustics.
Very good suggestions, thank you. I've also thought of another idea: I could
use an area light to soften the artefacts, then the refraction should hide
that well enough.
I'll have a play with these ideas and see what works.
Tek
Date: 6 Nov 2005 22:50:00
Message: <web.436ecdb86a680cb9d5d3b08c0@news.povray.org>
> that well enough.
> Tek
You might try using the spotlight with a large fade radius for your
forground(photon) lighting.  Then the number of photons fired should
gradually
decrease with z distance.
